A friend gave me a cherry bowl blank but it has some cracks that concern me. This picture shows a crack on the face grain that descends into end grain and then seems to follow a growth ring. Could be ring shake as I understand it.
That looks pretty bad to me. I try hard to save nice blanks, and I'll work around or with some minor cracks, but with this one, I'd be concerned about safety, as well as the attractiveness of the end product. If it were mine, I'd be tempted to chainsaw away the cracked part and turn the rest into something smaller -- if it's not also cracked on the other side too. Per John Jordan, "Life is too short to turn crappy wood." ...Gary
but split it open on the crack on the pith and use the other side for a smaller vessel. Maybe cut around the bad half and make some boxes or ornaments. There are lots of smaller projects that could be made, but to use that blank for the bowl intended is inviting disaster.
It could be done, but is not worth the extra work to get a finished product or the extra risk, which is considerable. I would have cut it for box or small hollow form blanks. Maybe tops.
Isn't this a great photo to give us the opportunity to clarify the "pith" statements that are made?
So here it is for debate and prediction is we will not agree on all of it but:
Ignoring the large crack for a moment, look at the pith area. It appears that the cut was made right down the very side of the pith. This is incorrect IMO but we are all guilty of saying "cut down the pith" when we should be saying, find the pith, move over 1/2" or slightly more and make a cut. Note where the crack ends (small one in middle) at the prominent growth ring. That ring is where it should have been split and I believe none of the cracks would be there, not even the big one. There is a lot of stress in those small rings in the middle. When the larger rings began to dry faster the little one's resisted and cause the large crack also.
Point is, by not removing more center rings it caused all the problems.
I'll also bet that this piece was too green before it was brough into a heated area. Green wood I air dry in unheated, no sun, area (garage) for several months before bringing into the shop which is heated all the time, I then try to put it in my home made kiln which I start out at 85 deg for month then go up to 95 deg for 3 months. I've had excellent success with this method.
As others have already said this is just not worth the trouble. Cut it down into smaller blanks maybe.
The other Don is correct about cutting a section out on either side of the pith when ripping logs into halves. Since I started doing it I have had much more success getting blanks that stayed solid.
