Sanding Disk Corral
Sanding Disk Corral
Sanding Disk Corral
dick gerard
Below is a picture of a holder I designed and built to corral my sanding disk holders. The holes were drilled with a Forstner bit to accomodate the 1 1/8 inch diameter hub where the metal spindle enters the pad. Disks of 180 grit and coarser have a firm interface pad whereas those disks 220 and above have soft interface pads. This interface pads protect the velcro on the disk holders. The disk holders are much more expensive to replace than the interface pads. This disk holder corral holds both the 2 and 3 inch pads as you can see.
Construction materials are MDF and plywood, held together with 1.25 inch staples from a Porter Cable pneumatic gun. The various holes are labeled for the various grits with a few extra, unused holes for extras.
Re: Sanding Disk Corral
Organization
Looks like a real time saver, Dick. Thanks for the look.
Walt Bennett
Walt Bennett
I've only one or two holders - just swap disks as I need.
Hey Dick, this set-up takes......
JamieDonaldson
...up less space!! :D
Dick at least has a spot for 60 & 80
I like it!!
Jorge
Monkey sees, monkey does...
Re: Hey Dick, this set-up takes......
Don Evans
I've got exactly the same setup right down to the same color holders, one is for 1" disk though and other is for 2" disk. I don't have all the holders don't see need for them, I have a special way to remove disk from them and one will last me for years.
Thing is, never take a hook and loop off without holding the foam down with your thumb, you need to actual compress the foam with thumb while you remove the paper. I also refuse to do any production work ever again I got till I go, whenever that is, but I can see where that bit of speed is helpful for those that do.
I made a passive articulating head sander many years ago with a hex 1/4" magnetic driver in it with ball bearings, only place to get hex shaft sanding pads that I know of is Packard here in good old NC, note you have one in top right, where did you get it?
Don
BarbS
Man, that's Serious!
Hey Don, that's an old sanding.....
JamieDonaldson
..disc mandril, and I have no idea where it was sourced. I have been a long time Packard customer, so it might have come from Brad years ago?
