a five sided handle
a five sided handle
a five sided handle
eliotandmax
It's easy to hold on center a six or eight sided handle in a conventional four jaw scroll chuck. How would you do it for a five-sided handle?
Re: a five sided handle
one way...
GaryG in MD
Turn a round tenon on the end. You can always turn and/or cut it off when you're done. ...Gary
Re: one way...
Or you could use a round collet chuck. If you don't have one of those large enough turn a scrap piece of wood in your chuck. Drill or turn out a hole to fit the five sided piece. Slide a bunch of slots in the scrap piece with a bandsaw and then put a hose clamp on the outside to clamp the piece in it.
Jam chuck ...
Doc Green
My suggestion is to mount a block at the headstock, using a scroll chuck, faceplate, or screw chuck, and then turn a recess of such diameter that the handle will fit into it. Then, insert the handle into the recess and use a cone center at the tailstock to engage the hole in the handle. Put a little pressure on it, and you'll be good to go. The recess only needs to be 1/4 or 3/8" deep.
If you want to drill the hole for the tool, ... that's another story. ~Doc
Re: Jam chuck ...
eliotandmax
It's the other story.Thanks though.
Drill the hole for the tool.
Doc Green
Here's one way to do it that doesn't require a collet chuck, steady rest, or anything else out of the ordinary.
1. With the handle mounted between centers, turn a short tenon on the back end of the handle.
2. Remove the handle from between centers. Use a countersink mounted in a hand drill to enlarge the point where the tail center was. The idea is to make certain the drill bit used to bore the hole finds the center. (You may skip this step if you use a spade bit or Forstner bit.)
3. Install the drill bit in a Jacobs chuck mounted in the tailstock.
4. Mount the handle in a scroll chuck using the tenon you created in step 1.
5. Bring up the tailstock, drill bit, etc., and seat the end of the bit in the recess you made with the countersink in step 2. Put just enough pressure on the piece to hold it in place temporarily.
6. Make sure the lathe is set for a low RPM, perhaps 400 or so. Start the lathe and drill the hole by advancing the quill of the tailstock. When you reach the desired depth, turn the lathe off, then pull the bit out. Remove the handle from the lathe.
7. Reverse the handle to remove the tenon you cut in step 1. Make a jam chuck with a tenon the same size as the hole you drilled for the tool. Slip the handle over the tenon and bring up the tailstock to hold everything in place. Remove the tenon from the end of the handle by turning it down to a nubbin, and so forth. And that's it.
Caution: Some brad point drill bits will tend to self feed and screw themselves into the wood without making a hole when turned slowly with considerable pressure applied. My suggestion is to use a conventional drill bit or even a good-quality spade bit. If you use a Forstner bit, it will need to be sharp.
And, as always, there are other ways to do it. Good Luck. ~Doc
Re: one way...
eliotandmax
I see that Doc Green and GaryG are both advocating pretty much the same thing( a method that I did really know.) The problem with these approaches ( unless you're starting with a fairly large diameter work piece) is that you need a chuck that closes way down. The spirit of my question had to do with the more interesting problem of somehow matching a four jaw chuck with it's 90 degree geometry to something with an odd number of sides, e.g., five, with non- 90 degree geometry. I'll try what John suggested -- or get a chuck that closes all the way down. Thanks to all.
