Cherry Vessel
Cherry Vessel
Tony Reynolds
Cherry Vessel
Tony Reynolds
Cherry vessel. It measures 12" tall over all and is about 4.75" in diameter. I had planned on doing a pedestal for it then changed my mind. Now I wished I had turned the foot in more. I may still remount it to fix it. The finial is ebonized cherry. I'm still trying to figure out my lighting for shooting high gloss finishes. I've tried indirect/reflective lighting but pick up all kinds of weird shadow lines in the finish. As always all comment and critiques appreciated.
Tony
Re: Cherry Vessel
Re: Cherry Vessel
Randy Gleckler
Very nice vessel Tony, Grain is amazing in that.
Re: Cherry Vessel
BarbS
That is a stunning piece. Very Nice.
Re: Cherry Vessel
Tony,
GaryG in MD
That's another beauty. The depth of the figure and finish is terrific.
It must really look great in person.
I also like the shape (the straight-sided foot being a very minor point to me) and the size and shape and color of the finial. (What do you use to ebonize cherry?)
It would probably look a tiny bit better sitting on a table if the foot were turned under a bit, but for such a small gain, it would be a lot of work to get it perfectly realigned for re-turning and then to have to blend in the new finish at that point. It all depends on how much it bothers you. You could probably turn another one in not much more time than it would take you to change this one. It'll sell the way it is!
...Gary
Re: Cherry Vessel
Tony Reynolds
Re: Tony,
Tony Reynolds
Thanks Gary. You are probably right, I have already started on another one so I should correct it there. Thanks for the input.
Tony
Re: Cherry Vessel
Tony Reynolds
Sorry Gary...
Tony Reynolds
I forgot to answer your question. I'm using Higgins India Ink to dye or ebonize the finials. I find it to be much blacker than the Transtint dye.
Re: Cherry Vessel
good to know...
GaryG in MD
Thanks. ...Gary
Re: Cherry Vessel
Re: Cherry Vessel
Philip Duffy
Tony, Leave it alone!! It is already perfect! Philip
Re: Cherry Vessel
Re: Cherry Vessel
I don't think I would turn the foot under. I think it's perfect. The curve is very smooth and continuous all the way down to the table and I like that a lot.
Nothing wrong with the photography. On reallyy glossy pieces you don't have any choice but to have a reflection. You can deal with the shadow by adding light to the back but on a vessel of this shape it will add another hightlight to the top when you do that. The light falls off on the sides making it look round and the smaller light shows off the grain.
You can place it on a black background and that will eliminate the shadow. If you would like a copy of my handout on photographing really glossy things just end me an e-mail and I'll paste it in one.
Re: Cherry Vessel
Tony Reynolds
Re: Cherry Vessel
Tony Reynolds
Thanks John. I haven't done many high gloss pieces in the past, but I'm kind of liking them. I dropped you and email.
Tony
