The language is Swedish, and the guys is presenting´as an instruction in starting to turn. The commentary is even more ignorant than the video, so you don't want to know - certainly it should not be spread around to unsuspecting beginners.
This gave me a good laugh this morning. I particulary liked the use of a hard sanding block in a cove! Truthfully, he should have begun his sanding with some 36! One can only hope that beginners DO NOT see this video!
It looks like he's teaching people how to poke at the wood with a dull stick. He sounds so sincere.... I peeked at Svarvning 1 & 2, and he actually uses a hand plane to take the corners off the piece before mounting it. I think they actually make a special tool for rounding square wooden stock like that -- the LATHE!
Geesh, that's just the crappiest turned surface I've ever seen! I can turn celery cleaner than that! Jesper -- If you can write in Swedish, maybe you can make a comment, or invite him to learn about cutting tools.
I am a production sander and it takes me all day to sand one balustrade I normally start with 10 grit Asphalt after I have used my chisel to open a can of paint it doesnt cut very well
