Big leaf maple critters
Skip Beardsley
I turned a large big leaf maple burl recently and before finishing it I brought it into the house and set it on a table. Been away on a cruise for ten days and when we came home I found piles of dust under the turning.
I am wondering what might be causing this and how to eliminate the problem. Neither side has had finish applied. Will applying finish effectively close in the critters? Any suggestions. I have a picture but do not know how to get it into this post/Users/skip/Desktop/Burl Debris.jpg tgrimmed resizes
Re: Big leaf maple critters
Carole Valentine
You could try soaking in DNA...the critters can't abide that stuff.
Keith Newton
Skip, I would put it in the microwave and zap it long enough to cook any critters that might be living in the wood. If you leave it out after zapping, there is a risk of drying too fast, which can cause some checking, but you can leave it in a plastic bag until it cools, without that risk.
Sounds like power post beetles. Get the wood outside and hope they haven't migrated to your kitchen table or cabinets; very destructive.
To kill them, you'll need to either poison (Bora-care or other activated borax preparation) or raise the wood to at least 180° F.
GaryG in MD
I don't like to do things to the wood that may damage it.
I don't know if this works for all bugs, but my first line of defense is to put the wood in a black plastic garbage bag for a week, closed up tight, with some moth balls. Usually works... ...Gary
Wood borers?
Doc Green
Here in central NC I have a big problem with wood borers. An adult is a worm about 3/4" long and 1/8" diameter with an over-sized head. Don't know if you have such a thing where you are.
For a roughed-out bowl blank with holes that indicate a borer might be present, I place the blank on a clean surface and wait for the dust to appear. The dust points me to the hole (1/8 or 3/16" diameter) that has an active worm. I then use a medicine dropper to inject a good squirt of lacquer thinner into the hole, then replace the blank on the clean surface. I keep doing this until I get no more dust.
Sometimes the critter will back out of the hole. Apparently they don't have a taste for lacquer thinner.
I've tried microwaving the blanks, but it didn't work. Obviously I didn't get the blank hot enough to kill them for fear of destroying the blank. I built a vacuum chamber, and pumped it down to 20" Hg with a blank inside, and held the vacuum for about 5 minutes. Didn't work either.
What does work is a woodstove. I've never seen a borer come crawling back out once I threw the blank inside. This winter, I've burned over 100 blanks of ash, not roughed out but carefully sawed out. sealed, and stacked, that the borers have destroyed. Good luck. ~Doc
Another alternative is to place the turning in a container that can be loosely sealed (such as a small garbage can) with a good sized chunk of dry ice. Do this in a garage or outside.
As the dry ice "melts" and release carbon dioxide, it displaces the air and suffocates the critters. After treating for a day or two, take the turning (or blank) out of the can. Carbon dioxide is heavier than air, so it remains in the container quite nicely for a while.
Ditto the moth balls- It works
Lewis Dodd
Hmm,,,interesting responses.
We have a similar problem with mesquite here in central Texas. Course, worm holes and worm tracks actually enhance the wood for some people.
You can walk by the wood pile and actually here the critters "hummin". The larvae are messy when turning at 500 or up rpm!
A garbage bag and a open bottle or container of household ammonia works for me.
Powder Post Beetles...
Wally Dickerman in Arizona
A few years ago I took a maple platter to one of my galleries. A few days later they called and said that the was small pile of sawdust under the platter. Yep, the critters were still alive and well in that platter. I suggested that the gallery up the price...hey, not all turnings come with live critters. Didn't work. I picked up the platter from the gallery and tossed it.
A valiant attempt, though, Wally
Ric Taylor
Ric Taylor
A slowly disappearing turning could be considered kinetic art ........ :)
Ric
Re: Powder Post Beetles...
don central illinois
Should have taken it a pet shop.
