i did it! not sure why...
darrin hill
so i've been trying to get glue of any kind to stick to wood... I'm using cocobolo, jobillo, bw ebony, ironwood, purple heart, maple and many others so they are not all the same wood.. the bails I'm trying to glue them to are all the same,... zinc plated nickel (i think) and the glues I've tried never worked..
i tried 5 minute epoxy and let it cure for 48 hours, jb weld, gorilla glue, and CA. If i tried with a tiny bit of effort they would all snap off.. and i didn't want someone to drop a pendant and the bail just pop off..
so someone said to drill and peg it.. Went to a local hobby store and got a 3/32 brass rod and clipped a 1/8th inch pice off.. drilled a hole from the front of the bail to the back and a tiny bit into the wood... Put epoxy on the wood, put on the bail, and inserted the brass peg...24 hours later it would NOT come off..
so..i then went to my grinder to grind the peg down a bit and was going to finish it with my dremel.. but the brass peg popped out and is now a separate piece... but the bail is still stuck on tight..
so do i just need to drill big 3/32 holes in both the wood and bail or is the peg necessary? i.e.... why did it stick and why does it still stick without the peg but the hole and peg were needed to make it work?
just a liberal arts major living in a mechanical world... looking for info... :)
Re: i did it! not sure why...
Alan Zenreich
Alan Zenreich
Darrin.
Perhaps these might something to consider.
In this crescent pendant I used two tiny screw-eyes... one on top one on the bottom
On this padauk pendant, I used an eye-pin glued into tiny bored holes (about .025") and held in place with thick CA glue. You could use a short version of the pin into a much shorter hole.
I show how I drill these kinds of objects in this video.... at about the 6 minute mark.
http://www.youtube.com/watch?v=HHjf4pnn33s
I hope this gives you some additional options
Steven Antonucci
Make your own hooks
steven antonucci
When I need something to hold, I usually start by taking a wire and twist wraping it to make my eyelet. I use a small drill bit as a mandrel to mak the eye around and then clip to length. By having it twisted at the bottom, I get more bite in the hole I drill for it because the twist acts a little bit like a screw.
CA glue has never failed, but if you are going to Dremel grind it, be careful that you don't heat it up. The heat will destroy most glues.
Steve
Darrin Have you tried contact cement. you can buy it at the hardware stores in small bottles for about $3. Is the glue coming off the wood or off the bail? Either one could have a coating of some kind that would need to be removed. I haven't had any problems and just use the clasps from hobby lobby. Nothing fancy. I use West systems epoxy.
Dick Hines
dick hines
All the woods you are useing are oiley. Try brushing on some Lacquer thinner to get rid of some of the oil.
There is a glue called J-B Weld. Give it a try. If it will not hold I don't what to tell you. It takes 24 hours to dry so you can't be in a hurry.
darrin hill
mine are hobby lobby bails too.. but i've tried ca, epoxy, gorilla glue, and jb weld.. the best one that worked was ca... but i had one pendant in my pocket last night that the bail just came off in my pocket on it's own..
never tried contact cement... is it a craft, model, etc glue?
Dale Miner
When the glue joint fails, does the glue remain on the wood, or on the ball?
Zinc coating on steel is a problem to get adhesion with paint, and requires special procedures and primers. I believe the problem with zinc is the surface has a thin film of zinc oxide that has low adherance to the metallic zinc underneath. The procedures for painting often involve a self etching primer (acidic), or a preparation acid wash immediately before painting.
I wonder if a quick touch with a Q-tip wet with white vinegar and a quick rinse with clean water might help with the glue adhesion, assuming the glue is coming loose from the ball.
Re: i did it! not sure why... *LINK*
Bob Macgregor
My approach is a bit like Steve's, except that instead of making my own, I bought a package of small, brass fishing swivels and clipped off the loop end, leaving some twisted wire base. This bit of twisted wire will sometimes thread into a pre-drilled hole (though not always), and the threads help form a mechanical bond with the glue.
I bought my swivels at WalMart, but here are some examples of various types that are available:
BOB
http://www.cabelas.com/swivels-snaps-clevises.shtml
