How to turn Burls?
How to turn Burls?
How to turn Burls?
Adam Baum
All - I am attempting to turn my first burl bowl and have run into a significant roadblock. There was a slight crack/knot/whatever-it's-called on the outside when I first mounted it. As I roughed out the exterior, what was a small "defect" opened up quite a bit. It was as if there was a huge irregular shaped air pocket with jagged edges going deep into the burl. My background is furniture and boxes so I resorted to what I would do for them - tape up any and all openings and apply epoxy. What I was not expecting, or thinking about, was the amount of epoxy required. I've got more than 6ounces in this 6" diameter bowl. Depth is about 5". That seems like quite a bit to me.
Four questions:
1) Should I not complete the turning due to the amount of epoxy used?
2) Should I have completed the rough turning inside and out and then taped up all openings, applied epoxy, and then a final turning?
3) Should I have approached burl differently than regular wood?
4) If I should keep moving forward, what would be the best (ie..safe) way to proceed?
Adam
Re: How to turn Burls?
Steven Antonucci
Welcome to WoodCentral *LINK*
steven antonucci
I never let a void in a burl stop me from turning it. In a great many cases, I use the voids to help turn a shape (gauge thickness, or hollow through them).
If you wonder how much epoxy is too much, check out Robert Chetalain's site.
Steve
Robert Chetalain
Ric Taylor
Ric Taylor
That's the thing about burls, they are very unpredictable, and you never know what is inside or what is not inside. Many burls are completely hollow, and you never know when a void will show up.
Ric
Guy Bratt
You don't nessessarily have to fill it. You can use it as a feature in the turning such as this. I'm sure you'll see many more.
Adam, *LINK*
GaryG in MD
Holes are decorative windows!
You'll have to decide the best way to handle your current piece, but, in the future, consider not using any filler at all. Mother Nature has presented you with a design challenge. Let it flow.
As examples of burls with windows, let me offer the following from the MCW S&T last month. Take a look at the 12th and 17th items.
https://picasaweb.google.com/106891946865477202075/MCWJan12Gallery#
...Gary
Brad Vietje
Brad Vietje
Adam,
Great topic.
Burls can be pretty tricky, and sometimes deceptive. After you've cut into a lot of them, you'll get a lot better at predicting how the smaller lobes are attached to the tree, to each other, how deep they go, and the infoldings and bark inclusions will get a lot more predictable. Not all species are the same, either. There's always an element of surprise, like the time I encountered a bunch of confused, and dizzy wasps inside a Black Cherry burl -- even after spinning at 500 RPM for about 5 minutes, once the lathe stopped, they recovered enough to chase me across the yard at a pretty good clip! :(
These inclusions and odd-shaped chunks of burl wood can also come flying apart, so stop often to inspect the wood, and consider different ways to keep it together. Some people wrap them in Saran Wrap, packing tape, etc... depending on what you're making. A search of the Archives will yield some good ideas, too.
If you post a picture, you can get more specific help, or some different ideas about how to complete the turning. Maybe not they way you intended, but something beautiful, nonetheless.
Safe spinning,
Brad Vietje
Newbury, VT
Three Suggestions
Here are three different treatments for burl turnings. On the left a maple with the wood oriented so that most of the burl grain is in the upper portion (no voids), finished with a light matte spray. On the right, a cherry full burl with significant voids left open and unfilled, finished with oil. In the middle, another maple, but this time with the voids filled with tinted epoxy before hollowing, finished with dye and waterborne lacquer.
When hollowing with voids, filled or otherwise, a role of stretch wrap is, at least in my shop, s.o.p. :D
Welcome to the Vortex!
Re: Welcome to WoodCentral
Adam Baum
Thanks for the welcome. Actually been lurking here for years, mostly on the other side.
Re: How to turn Burls?  *link*
Adam Baum
Here are the results of my endeavor.
http://woodintosawdust.wordpress.com/2012/02/03/epoxied-maple-burl-bowl/
Adam,
GaryG in MD
All things considered, not a bad effort. The wood looks nice, and you really didn't have much of an option with the shape, given the big hole there. Well done, Gary
