Undulations: Controlled Burn
charlie belden
Turners spend a great deal of time either sanding, or developing turning techniques, to produce as perfectly smooth surface on pieces as they can. Often the wood surface is made even smoother by applying a glossy finish. The result can be stunning - and shiny. And that can be a good thing.
But if the resulting piece looks like it might be glass or porcelin or plastic, and the wood becomes lost . . . ?
So turners use piercing and pyrography, carving and texturing, dyes and stains, to change the surface look of the piece - and remove most or all of the impact of the wood, and the nature of of the wood.
One of the qualities of the nature of wood is that it's a grown medium. It literally grows on trees, or rather in them. As a result, it has growth rings. And it doesn't always grow at a fixed rate, or symetrically.
In the winter it grows slowly- and the wood added is dense. In the spring its growth rate increases rapidly to support budding leaves and branches. Slow growth - dense wood Fast growth - less dense wood.
So how can this harder/softer wood quality be exploited?
One way is to sand blast it - abrading away the softer wood more than the harder wood to hopefully add an interesting texture to a piece. And areas can be protected from abrasion, with masks and frisket. IF you have a sand blaster, this is one means of exploiting the harder/softer wood quality.
Another way is to use FIRE - soft wood burns faster than hardwood. Propane torches are readily available and inexpensive. There are even small "pencil flame" torches that can give you more burn control, allowing you to even write or draw on a piece.
But there are other means of controlling how much wood is burned away - and where - by controlling what areas are exposed to the torch flame.
These two examples are of redwood fence boards. They were layed flat, noiyo pebbles placed on them where I wanted the wood protected and a propane torch was taken to the wood. A wire brush removed the charring and the process was repeated. The result was an undulating surface of contours, small islands separated by water of different depths, wind and water carved mesas rising above ancient rivers bedsand flood planes.
That's pretty crude at turning scale, but there's a method that traditional Japanese cutting tools makers have been using for half a millenniaor more - to heat treat and heat color metal - CLAY. Clay is a heat insulator. As a paint or paste, it can be aplied, thicker for more insulation / protection from heat, thinner when less insulation / protection from heat is desired.
You can pick up "kiln wash" a refractory material that comes as a fine powder from ceramic supply outfits. Mix it with water, or better yet alcohol if you're in a hurry, paint in on, let it dry, add more and so on. When dry, get out your propane torch and do some experimenting. Woods with wider growth rings with hard winter wood and softer spring wood could produce some interesting fire carved surfaces,
