Fire Extinguisher & Smoke Detector Reminder
Nick Todd
Last January, I had a small fire in my shop. I had just brought a finished piece into the house and I decide to send an email. After a few minutes, I smelled smoke and returned to the shop to investigate. I opened the door to see smoke down to the five foot level throughout my shop. At that time I didn’t have smoke detectors in the shop. I kept two fire extinguishers at either end of my shop. The handle on the fire extinguisher failed(it was commercial grade). The other fire extinguisher was behind the fire. I was regulated to the garden hose. The fire was start by a heat gun that either shorted out or I kick on the heat gun on. In the latter case, I am assuming it did not hear the heat gun because of fan noise from a space heater.
In my outlook calendar I have a January reminder to inspect & replace fire extinguishers & smoke detector battery’s in my house & shop.
Lessons learned:
It took less than 30 minutes & $25 to install two smoke detectors. I had always planned on installing smoke detectors, it just never happened.
If I had inspected my fire extinguishers more often, the damages would have been far less.
My shop is in my attached garage. When I started to buy equipment for my shop, I put in a sub-panel to provide protection to my lathes & compressor. That protection worked. Because I had my shop lights on a separate circuit, the lights stayed on when the outlet breakers were tripped. It would not have been fun to put the fire out in the dark.
Re: Fire Extinguisher & Smoke Detector Reminder
Ken George
This post reminded me that I have to get smoke detectors for my new shop. What is the appropriate one to get?
Thanks,
Ken
Terry Scott
I installed (hard wired in) smoke detectors for my work shop to the burglar alarm system
The problem has been that they went off so many times they became sensitized and even a whiff of solvent or branding would set the alarm of .This is one of those sirens that is so load you have to get out or you do damage to your ears.
I have considered having heat detectors only as the alarm people said all smoke detectors would be affected by dust and unless blown out daily start going off
The smoke detectors are still in place but I admit I have tapped them over foolish yes
But my reasoning if it gets hot enough to melt the tape they would act as some sort of protection if even to late
The smoke from Phyro work is enough to set the detectors off so they dont need much
Having my workshop under my daughters bedroom is a constant worry.If I did have a fire with all the chemicals and finishers it would be an inferno
Apart from building another shed any suggestions
I do have 3 fire extinguishers but they wont be any help unless I see the smoke
Stuart Johnson
With your shop being under your daughter's bedroom you might want to consider adding some sort of fireproof panels on the walls and ceiling.
At least twice a year, you need
John Kaner
to check your fire extinguishers. You turn them upside down and tap with a rubber mallet. The powder will settle and pack. If there is a gauge, it is usually refillable. Even single use/one time extinguishers need the powder shaken... Yes, they are charged with nitrogen. They are still worked on in open air. The seals are lubricated and all parts including the pick-up tube are cleaned. You check the gauge, as all seals will eventually leak. Yes, nitrogen has larger molecules. Just like your car/truck tire loses air over time...
There are rate-of-rise detectors that see that spike in temperature. They're not sensing smoke or fumes... These can be connected to your alarm systems...
There are also H.A.D. Heat actuated devices that can be connected to your alarm system...
Most common smoke detector is an optical type, the beam inside is broken by particulate in the air. Anything that "breaks" the light beam, sanding dust, burnt toast, etc. These are the least expensive and responsible for the greatest loss of life. Folks take the battery out or shut off the dedicated breaker to prevent the false alarms.
The second type has a small amount of radium and reacts to the products of combustion. Less sensitive to sanding dust, still react to dull blade and maple being cut and that whiff of smoke. The smoke is layered with products of combustion.
Another thing that leads to unnecessary loss of life is not replacing those 9 volt batteries in your detectors on a regular basis. Every Fire Prevention week, you should replace them. Even hard-wired systems have a battery back-up. That annoying"chirp" that you have to follow around and find which detector... Folks have taken the battery out or flipped the dedicated breaker, voila', no more "chirping" at o-dark thirty... Whole families have perished due to doing this... Replace those "spendy" little 9 volt batteries each year and be around to complain...
Sorry about the soap box, between Volunteer and USAF Crash/Fire/Rescue, I have over 20 years experience and I've seen things that still give me nightmares...
The best way I remember to ..........
JamieDonaldson
...change alarm batteries annually is to give myself new batteries on my birthday! Since many of us have to turn off the smoke alarms when blowing out all those birthday cake candles, that is the best time to also replace, after all the smoke clears! :D ;)
Mike Stafford
I remember to change batteries.....
Mike Stafford
when the clock changes from Daylight savings to standard and also from standard to Daylight savings.
Twice a year is good for these important devices.
Harry Robinette
harry robinette
We should all remember to have a CO detector in our shops and change it's battery too.
Another problem you may encounter
Mike Foster
with the ionizing detector is with fluorescent fixtures. I just replaced a very old hall light (Probably dates to 1935) with a new fixture and put some CFL bulbs in it. Turn the light on and beep, beep, beep!. I knew the wiring was all good and there was not a hint of smoke. After searching a bit on the web I finally did find a reference that the ballasts in fluorescent fixtures can put out enough electrical noise that it can trip the alarm. The detector should be at least 3 ft from a fluorescent fixture. I move ours about 4 feet away, and it has still tripped the alarm once (if it trips again I may have to move the alarm again).
ok then..........
Nick Todd
Will a natrual gas leak cause a C02 alarm to go off?
No, CO is Carbon Monoxide and
John Kaner
Natural gas is odorless, tasteless. They put "stink" into it, so you know. You can get a natural gas or propane leak detector from a RV Center or various Alarm Centers (ADT).
To check for a gas leak, natural or propane, you use a kitchen soap mixture. Bubbles at the joint indicate a leak.
Re: No, CO is Carbon Monoxide and
Dale Bonertz
You mean you just don't holder a lighter around the suspected area. :D
Do not try this - I am kidding.
