We have finally got an agent selling Kelton In New Zealand
About B time how many years has it taken
I have in the past had to get anything I wanted out of the states or Canada
Know that you are not allowed to bring large bits of metal in your hand luggage is a problem
So for a bit of retail woodturners theropy I shouted myself ( well actually I could not help myself)As it was so nice just walking in and saying Ill have one of those.
I have since re sharpened the cutter like I do all my scrapers like a skew from both sides
My reasoning is that a flat edged scraper will pick up the end grain and draw the handle down pulling the cut into the work BANG!! big dig in .Were as the shape I use the fibers are coming onto a bevel so if the grain is caught the handle goes up and the wood is ridding the bevel forcing the tool outwards and clear
Try scarping with a grind like this and you will become converted
Most of our timbers dont take to kindly to scraping but shear scraping with a razer scape edge seems to work
I've tried using my round nose skew as a negative rake scraper - catch time! I have used the smaller straight edge skew - very carefully, with positive results. I've also regound the top of my flat nose scraper with the recommended 15 deg bevel. Problem is, it doesn't seem to help any, because I to get the same affect with or without the top grind.
The big "bang" is precisely the reason for the adjustability of the Kelton Multi-Axis...set it to a shearing angle with a slight negative rake and it is sweeeet! If you do run into trouble it kicks down and away. In fact if you are really a nervous Nelly, you can not crank down on the clamping screws quite as tightly and if for some strange reason you should get a big catch, the cutter assembly will move back away from the cut. Sort of the same safety thing that is built into the Kelton Hook Tool. The clamping pressure should be adapted to one's own turning style.
You can put a bit of a secondary bevel on it, but it's not really needed. The ability to adjust the cutter to a negative rake accomplishes what you are doing by grinding your scraper tips to a skew configuration.
In fact, I hope you did not grind your Kelton the way you have shown your other tips ground, but from what you have said apparently you have!! If you did, you have removed the cutting laminate from the top surface and ruined the tool.
I did see Kel with those scrapers at the Symposium. I didn't pay too much attention to them. Did he really laminate the hard steel on to the top surface of them like he does on the coring system?
The first photo shows the scraper at a shear angle. This is a much more forgiving cut, and cleaner cut than the scraping cut/flat on the tool rest cut. It will not catch as long as you are on the lower third of the blade, similar to how you are supposed to cut with a skew. Been using that cut for years, and with a good burr, it will clean just about anything up nicely. Never have gotten the hand of the NR scraper other than for the top of slightly domed boxes.
If your getting catches using the skew as a scraper have the handle too low. The tool should be presented with the blade flat and handle higher than the cutting edge. Just like any scraper.
If you use it as a shear scraper which is holding the tool edge at about 45 degrees then the only reason you get a catch is if the cut gets above the center. You should also be pulling the tool so the handle leads the cutting edge.
Yes, Reed. Shame you didn't have the opportunity to try one of the scrapers at the Symposium. And I agree with the importance of a shear angle...then it's is not a "scrape", it's a clean cut. I can get "angel hair" shavings with mine....or gorilla shavings if I've a mind to take a lot of wood!
The reason I didn't try it was because I could not see that it would do anything that I can't do with standard scrapers. All the articulated head does is change the cutting edge presentation to the wood. You do the same thing by rolling your scrapers up on edge. You scrape, or shear cut. Same reason I never use a tear drop scraper on bowls.
