Odate's Might Oak
charlie belden
A woodworker’s relationship with wood is an interesting one.
Some woodworkers see wood merely as a medium with which to make things they’ve already decided on – and have already developed a plan or set of plans for. The wood for a piece is usually selected preprocessed, with straight edges, square corners, parallel faces and edges – S4S boards or planks - many steps removed from the tree from which they came. If there is any connection to the tree or trees the wood, it’s remote and plays little if any role in the design of the piece other than perhaps its working qualities. color and grain or figure.
Turners, usually spend thrifts when it comes to wood for turning, but spend money like drunken sailors when it comes to tools and equiptment, have a closer relationship with the wood, and often to the branch or trunk of the tree from which the wood came. Whiile Flat Workers can ignore the sound of a nearby chainsaw running, and presumably cutting, turners’s are finely attuned to that sound and often have a Pavlovian Response to the sound, knowing, or at least hoping, that some very nice wood is or will shortly be available – for free.
As turners, the more we know about the piece of wood to be turned – does it contain tension, or compression wood – where the pith was in the original piece of the tree this wood is from – what time of year the wood was first cut, how long ago was it cut – these can be important when deciding how to orient the blank and how to turn it.
Then there are The Few, who develop a much deeper relationship with wood – and the tree it came from. James Krenov comes to mind, as does George Nakashima, who even wrote a book about that relationship called, appropriately enough titled “The Soul of a Tree”.
One man has an even deeper connection to trees, the wood that he saves from them and the tools he uses to do that with. – Toshio Odate. If, for some reason, the name is unfamiliar, or even if you know of and about this man – pick up a copy of the Winter 2012 Woodwork magazine and read his article “Odate’s Might Oak Fights Back”.
I have both of his books and have read every article by or about him I can find But this article really took my respect for the man and what he does, and for the wood I get to interact with, up a notch.
If wood doesn’t “talk to you”, I highly recommend reading this article. I assure you, the time spent reading, and thinking about what you’ve read will definitely be worth it . You may not come away with the ability to converse with wood – but you’ll certainly gain an appreciation of this wonderful material we call wood – and of trees.
And BTW, the interview with Todd Hoyer in the same issue is also worth reading - and looking at the pictures ; )
