Craftsman spear point turning tool
Tim O'Hearn
What is the Craftsman spear point tool used for? I have it as part of a set I inherited.
Tim O'Hearn
Re: Craftsman spear point turning tool
Guy Bratt
If it's wider in the center,I believe you have a parting tool.
Tim O'Hearn
Thanks, but no. This tool is 1/2" wide. It is flat on one side and the other is tapered from both edges to a sharp point. The edges of the tapered area are also sharp.
Some kind of scraper?
Don at Central Illinios
Picture please. I can't figure it out from your description.
Tim O'Hearn
Don - On page 9 of the following pdf, page 13 of the catalog, ( a copy of the 1966 Sears Tool Catalog) the spear point tool is No. 24.
http://www.scribd.com/doc/34960285/Sears-Catalog-1966
Sorry, I don't have a digital camera.
An almost useless shape for a scraper
steven antonucci
I know what you mean, and I never used it, so I reground it into a half round scraper. I think that you might be able to scrape the inside corner of a box with it if you wanted to have a square corner. I use a skew presented like a negative rake scraper instead.
Steve
A very useful tool in knowledgeable hands
I know it was designed for use as a scraper or simply to cut V cuts. However my best friend grew up with that tool and used it in different ways. For those who don't know the description above is correct. It is flat on top, has a V shaped tip and is ground like a scraper on both sides of the tip
It can of course be used as a scraper but is better to use is as a shear scraper for both left and right travel. Tilt it left and use it the left hand side and it's good for shear scraping to the left. Tilt it right ,use the right side and it shear scrapers to the right.
Now here's the fun part. It makes a great skew. My friend says he can't use the skew but what he does with this tool is the same. He used it to undercut the bottom of goblets. He places the flat side against the wood which acts like a bevel and then pushes it in so it cuts very much like using a skew with the toe down. I've also watched him cut a bead with the flat side down, again just like using a skew.
jim 9 miles
I have one also---make a great paint can opener !
Doc Green
Richard Raffan describes a spear-point scraper at length in his book, Turning Wood. It is used in the shear-scraping mode and is good for getting into tight places, like scraping into a corner.
Jim Breeden
I have one also, and use it as jim 9 miles described. Probably not even as good at it as j9m -
Guy Bratt
I know which one now it was a toss up before. I use it as a scraper for dovetail tenons and sometimes when turning acrylic pen bodys
Don at Central Illinois
Nah, that's what a skew if for.
Richards is the same thing but the blade is much wider so you have a much longer surface which makes it easier to scraper without catching one of the edges.
robo hippy
I had a Raffen spear point scraper, and converted it into a negative rake scraper.
robo hippy
Betty Scarpino
Tim,
I learned turning in the late 1970s from Dabney Doty, an industrial arts professor at the University of Missouri. He previously had been a patternmaker. In the woodshop we mostly had Craftsman tools, and we used the spear-point scraper as a roughing tool. It worked great! I still occasionally grab it to rough out a bowl, especially for out-of-round bowl blanks.
Here's a photo of mine.
Mike Brazeau
I have one of these from an old Delta set of high carbon steel tools I got with a used Delta Rockwell Homecraft over 40 years ago. I use it when roughing bowls to tidy up the tenon face immediately adjacent to the point of the live center. To sharpen I just run an Arkansas stone or diamond lap across the top.
Don Evans
I also have had one of these since mid 70's and it is an extremely handy tool if you know what to use it for. I've never considered it a roughing tool however. But it can be used with point in up position below center handle above tip and scrape pretty little "v" grooves, very shallow ones, great to disguise where top and body of small boxeds come together.
Turned on either side it can be used to make half "v"'s, flip it over to other side and move 1/16th inch and make another 1/2 "v", and it can be used as a skew with tool rest raised, tool on it's side. BUT what I like it for most is doing the bottom on a goblet or finial etc, turn on it's side use the point to catch the wood for the bottom of a goblet or finial and cut slightly towards the top of the object so it will sit flat or in the case of a finial fit a rounded surface with no gap.
This was a great production turners tool as you didn't have to keep changing tools to accomplish all these task. It would take 3 tools to replace it for me. Oh forgot, I use it to make dovetail for Nova chuck jaws when making a tenon to be mounted in chuck, do this while it is still in spindle set up.
Don
Tim O'Hearn
Well, there are a number of uses for it I see. I will sharpen it up and try it out with the suggestions listed.
Thanks.
