Epoxy or CA?
Epoxy or CA?
Steve Kubien
Epoxy or CA?
Steve Kubien
I know one of these can be "dissolved" by heat, but can't remember which. I want to put two things together but I'd like to be able to get them apart if this project completely fails (a little metal work).
Thanks!
Re: Epoxy or CA?
Re: Epoxy or CA?
Bill Howatt
Epoxy is weakened by heat but I've never thought about its effect on CA.
Bill
Re: Epoxy or CA?
Ken Vaughan
Re: Epoxy or CA?
Ken Vaughan
CA glue softens and fails with heat -- starts to go about the temperature of well done roast beef = have used a warm oven to separate items.
Many epoxy glues are also heat sensitive, but generally at a little higher temperatures.
CA tends to be weak in shear and sensitive to impact.
Re: Epoxy or CA?
Steve Kubien
Thanks guys
Steve Kubien
Looks like I'm good either way. Heck, even it doesn't work, I'm not out money (spare parts) or time.
Cheers
Re: Epoxy or CA?
Re: Epoxy or CA?
Emmett Manley, Lakeland, TN
Strong epoxy bonds -- think golf club heads affixed to shafts -- are broken easily by the flame from a small torch.
Re: Epoxy or CA?
Re: Epoxy or CA?
Scott Hurley in N VA
Actually, they say that if you leave your golf clubs in your trunk on a hot summer's day, you can weaken the epoxy enough to have the head fly off. I'm not sure if that's the reason, but I've seen several driver heads go farther than the ball.
Re: Epoxy or CA?
Re: Epoxy or CA?
eliotandmax
A standard way to make a a certain kind of hollowing tool is to attach a sharpened machinist's bit to a metal rod with CA glue. Then, when you want to take the bit out of there, you just heat it with a torch and it comes right out.
Re: Epoxy or CA?
Bill Blasic
Re: Epoxy or CA?
Bill Blasic
I made golf clubs for 15 years and I'll tell you that it takes a lot of heat to break the epoxy bond and unless the gas tank under that car is burning your heads will not come loose inside a trunk on the hottest day. If that happened someone used inferior epoxy. If I was choosing between epoxy and CA with heat in mind it would be a good epoxy.
Bill
Re: Epoxy or CA?
Re: Epoxy or CA?
Barry L Elder
I agree with Bill. A good epoxy glue usually requires heat in the vicinity of 450 degrees to break down. This does not apply to 5 minute epoxy.
Re: Epoxy or CA?
Re: Epoxy or CA?
Lee Buck
There is a story included in some of the WEST System epoxy literature about a company that wanted to sell wooden boats bonded with epoxy to the Navy. They didn't get the contract because the joints failed a boiling test. After that the company put a sign in thier boats something like "Do not moor over an active volcano. If you find you have moored over an active volcano-move."
