Veritas - Innovation in Tools
White oak lidded box -SJPT
Roger Chandler
This is another lidded box from the Stonewall Jackson Prayer Tree.......a civil war era white oak that General Jackson and his troops gathered around for prayer during his Shenandoah Valley campaign in May and June of 1862. It was he and approx. 15000 soldiers who camped out between the middle and south rivers here in the valley.
Box is 6 inches high and 3.75 wide at the base.
Re: White oak lidded box -SJPT
Nicely done - Re: White oak lidded box -SJPT
Henry (Raleigh, NC)
Nice piece Roger. Of course the history of the wood makes it that much more unique. Did you leave the inside unfinished? It looks that way in the picture.
Henry
Keith Tompkins
Keith Tompkins
Hi Roger, would you mind if I did a bit of a critique of this piece?
Re: Nicely done - Re: White oak lidded box -SJPT
Roger Chandler
The inside is sanded to 240 grit and has two coats of shellac........the outside has 2 coats of shellac and 2 coats of General finishes woodturners finish.
Roger Chandler
Fire away Keith!
Keith Tompkins
Keith Tompkins
OK, brace yourself....just kidding. Really, the thing that struck me on this piece is the box is an end-grain turning , while the lid is cross-grain, similar to a bowl orientation. The wood in the box and the lid will move in different directions over time, especially during seasonal changes. The box will move fairly uniformly, the diameter of the opening will be subject to change. The lid will move in and out in one direction, and only a negligible amout in the end-grain orientation. As a result, the fit of the lid may be subject to wide swings over time, and possibly get stuck during humid weather. Also, the ball at the top will be prone to snap off if dropped, or if the lid is tight and someone tries to force it open. The wood doesn't have a lot of strength in that orientation. I hope this may save you some grief in the future...I like both boxes you've posted, nice work!
Roger Chandler
Thanks Keith! I was aware of this cross grain situation on this box........unfortunately I had to work with what I had in this particular piece of wood, and because of the fit issues, I have made a little allowance for movement.
At first it was a real fit.......suction when you pulled the top.......thought better of it, and went ahead and gave just enough where movement should not be a problem..........not ideal, but with this particular piece of wood and the issues it had as a blank, it is what it is.........thanks again for your comments....appreciated!
