Wine Glasses
Ray Carson - Lawrenceville, NJ
These are Maple and Spalted Dogwood wine glasses I made for some Christmas gifts.
Goblets were purchased from Craft Supplies with a 1" long stem in place. Bases are turned and drilled to accept the goblet. They were a HUGE hit.
Sanded to 600 grit then finished with Micro Mesh pads. Three coats of clear spray lacquer were applied with a light sanding in between coats. They were then buffed out and waxed. The two are joined with waterproof / flexible epoxy.
I can't explain the dark ring around the Maple base. My only theory is that the heat from parting off the waste with the parting tool somehow discolored the wood. It was pretty uniform so I left it. This is one of those "Ides thingys" Ellis was looking for I guess. It wasn't a mistake but it wasn't intentional either.
