Handwheel
Jim Rutten
I bought a handwheel hub from oneway several months ago and am finally starting to think about creating one but have some questions. First, on the faceplate side, for some reason there is a section that stands proud of the flat faceplate. My guess is that you are supposed to drill the hole to the diameter of this piece such that the outside of the piece is flush against the wood. Does that seem right to you? What kind of wood would you use to make your handwheel? What diameter would you make it? How thick would you make it (I have turned on lathes with pretty thick handwheels and I like them that way, but I am not sure if it is anything besides pleasing to my big hands)? Given that they will become permanent, what kind of screws would you use? Anything else I am forgetting?
