Fixing the Axminster Eccentric Chuck
Dave Staeheli
I've been playing around with the Axminster Eccentric Chuck for multi-axis work. It has its good points and not so good points. It is probably the cheapest eccentric system out there, and perhaps a good entry level multi-axis specialty chuck. Three things I definitely like about this chuck over holding the piece within only two jaws of an ordinary chuck or one of the fancier eccentric chucks. One is: repeatability. If you go away from one axis, it can be returned to accurately at a later time. Two is: Not being limited to two or four axis. While technically there could be as many as twelve axis with four to eight offsets, it is very nice to be able to construct a three sided shape or a four sided shape without much calculation. The third thing is: Security. If your wood screws are secure and/or your glue joint onto a waste block is good, you don't have to worry over much about it dismounting. It is effectively faceplate work rather than depending on chuck holding power.
There are a few minor problems that I have fixed. To help my fading memory, I stamped numbers zero through eleven on the center rotational block above the factory marks. Saves counting the marks when I shift axis. I have also filed a marker groove on the offset plate and corresponding grooves above each offset hole to avoid fiddling when trying to line up the screw for a new offset. On the rotational block, I drilled the holes to a larger size where the woodscrews go to hold the piece or wasteblock. They originally would only take a number eight or ten wood screw, and I wanted at least a number twelve screw as there are only three of them. Perhaps the smaller screws are fine for small coasters or box lids, but I've been taking things quite a bit further. Probably further than I should.
One minor problem that I have yet to over come is that it is somewhat awkward to loosen or remove the offset screws when the piece is overhanging the screw placements. It takes an allen wrench in sometimes tight spaces. Makes for slow transitions from one offset to another or back to zero.
The big problem as I see it is the steel dovetail chuck ring. This plate is intended to mate with a set of dovetail jaws on your scroll chuck. As advertised, it is supposed to mate with 2-3/4” diameter dovetail jaws. I think this might work fairly well if you were using an Axminster chuck with the jaws closed down fairly tight. With my chuck, a Oneway, the jaws have to be open fairly far and there are only four little points of contact. With all the flexing and vibration that occurs when turning off-center, the eccentric chuck kept being knock askew or even dismounting. Very frustrating!! I imagine this problem may occur with any scroll chuck that was not an Axminster.
My solution was to get rid of the scroll chuck and the dovetail ring and to mount the rest of the eccentric chuck directly onto a face plate. A much simpler and stronger mounting system. The trick was to come up with a way to machine a faceplate substitute. It turns out that the dovetail ring is exactly 4”, the exact diameter of a Don Pencil M33 - 3.5 faceplate and very close to the diameter of a Woodriver 1”- 8tpi faceplate. How convenient that these fit on my two lathes. Unfortunately if you have any other spindle size, you will not find an exact match faceplate. I think there is a way around this, but I didn't have to go there.
So it turned out to be easily doable. I needed an appropriate faceplate, a 4” hoseclamp, a 3/8” drill bit, some 3/8” aluminum rod, epoxy, a 5mm or 3/16” drill bit and a 6mm tap. What I was doing was matching the threaded holes on the dovetail ring and transferring them directly onto the faceplate with zero error.
The problem was, when the two were clamped back to back, some of the holes on the faceplate ring were impinging on the original faceplate woodscrew holes, but no exact match. The solution was to fill the woodscrew holes. I thought originally that three holes would have to be filled, but it turns out only two of them were needed. I chose to drill out the offending woodscrew holes to 3/8” and epoxy in a short length of aluminum rod. I made them just slightly longer than the faceplate was thick. It was a simple matter after the epoxy was set to mount the faceplate on the lathe and turn them down flat.
Then to drill and tap the offset holes on the faceplate. Clamping the dovetail ring and the faceplate together, I tightened the 4” hoseclamp around both. Voila, the ring and faceplate were held securely for error free drilling and tapping. The dovetail ring, being steel, makes for a nice drilling and tapping jig. I simply ran the 5mm drill bit through each of the required ten holes, and then ran the tap after it. A bit of cleaning up, and I had completely replaced the dovetail ring and the requirement for a scroll chuck. It took a bit of thought, but rarely have I had a project go so smooth and it works darn good too!
I've included some photos which I hope are self explanatory. No way do I have pretensions of being an expert photographer.
