Grip 2nd time on a twice turned piece?
Henry (Raleigh, NC)
How do you grip a twice turned piece if (when) the tenon or recess has become oblong during drying?
Henry
Re: Grip 2nd time on a twice turned piece?
Steven Antonucci
Make 2 center marks before bagging
steven antonucci
remount and retrue the tenon.
Alternatively, just grab the tenon and squeeze it extra hard.
Either way works.
Steve
Re: Make 2 center marks before bagging
Henry (Raleigh, NC)
ahhh so many assumptions Steve. Remount - but how do you do that?
I suppose you mean to leave the center of the bowl thick enough to remount the piece between centers and use a spur drive in the concave interior. Doesn't that make the bowl center/base much thicker than the walls and therefore dry more slowly?
I guess when I look at the oblong tenons my sense has been the chuck won't necessarily hold well enough - so I have not tried that option.
I have Nova 3000 with 16" swing so I am not doing huge pieces, but to date my flying saucers have not been much appreciated.
Henry
Jam chuck ...
Doc Green
If it's a bowl with a tenon, jam chuck it against either a flat disk or an internal jam chuck and re-true the tenon.
For a different type of piece, put it back between centers if possible and re-true the tenon, or improvise a jam chuck.
A recess is a bit more of a problem because the tailstock gets in the way when you try to re-cut the recess. Options depend on the type of piece and the severity of warping. Cole jaws might work, or a vacuum chuck.
Good Luck, ~Doc
Bob Verne
Henry, you grip the bowl between a chuck and a live center in the tailstock. The chuck jaws are opened half way or more to get a bite into the bowl. Depending on the size of the bowl, gripping with only the edges of the jaws might not be a good fit. In that case, make a kind of a jam chuck sized for a loose fit in the bowl. To improve the grip, put a piece of rubber, e. g., a piece of stiff foam carpet padding, between the jam chuck and the bowl.
You should have a dent in the center of the base from your original turning where you engaged the live center. If you have cut away that dent, you will have to create a new one. The new dent may not be as centered as the original, but all it needs to be is close.
Then re-true the recess or tenon. You don't need a very strong grip, because all you are doing is making light cuts to re-establish roundness.
Bob
Steven Antonucci
Same lathe... another idea
steven antonucci
If you have to rechuck a bowl and the tenon is out of round, make a taper that you can hold in your chuck and use it as a friction drive on the inside of the bowl. Put the tailstock center point back in the original center mark in the oblong tenon and retrue it.
QED.
Steve
Dale Miner
Most of the others have answered, but here is the way I do it.
In the rough out step, the blank is mounted between centers, and the witness mark from the center remains. When dry, the bowl is jam/friction chucked between the tailstock center and the chuck jaws. It is necessary to rotate the bowl against the jaws to find a spot that all four jaws are bearing on the wood, and then increase the pressure of the tailstock. I recut the tenon, and also form the foot and cut at least an inch or so of the bowl bottom from the foot out. This helps reduce the need to put the gouge up close to the chuck after reversing. Sometime, I recut the entire outside of the bowl in this step. After the tenon, foot, and bowl bottom are recut, the bowl is reversed into the chuck and the rest of the bowl returned true, outside first if not already done. If the bowl is so deep that it hits the headstock when reversed on to the chuck, then a wooden jam block is chucked up to keep it away from the headstock and the same process used.
For hollow forms, the same process is used, except a plug is chucked up and the plug turned to just fit the opening of the hollow form. Usually on a hollow form, the foot is not turned on the first remounting, as the tenon is larger than the final foot size will be. In this case, after the second turning of the outside including the opening (and inside of the form if needed), a new plug is turned to fit the opening, and the foot is finished to a nub, and the nub cut off with a hand tool of some sort. Alternatively, a long spindle is chucked and turned small enough to reach the bottom of the form with the diameter larger at the opening to just fit, and the foot is finished to a nub. The second method is safer but more time consuming.
Brad Vietje
Brad Vietje
Hey Henry,
You've gotten some great info, but I think a few assumptions have been made, and a few critical bits are being left out.
I may repeat other comments, but I'll try to include the missing bits:
1. Many turners start a bowl between centers, so you can make small adjustments to the position and tilt of the rim and foot for the best results (usually to balance figure, growth rings, sapwood, etc...). When forming the tenon, leave a small stub at center with the mark made by the tail center for use later.
2. If you start with a screw chuck or a face plate at the rim of the bowl, you give up some of the control over these factors, and you would not have a tenon with a mark from the tail center. Even if you don't start between centers, you can bring up the tailstock specifically to make a mark for re-chucking later.
3. I start all bowls between centers, and always leave the tail center impression for re-chucking later. I rarely leave anything inside the bowl, unless I turn a recess or ledge for chucking in expansion later.
4. To re-chuck an oval bowl, either set it over the chuck and hold it in place with pressure from the tailstock (as Doc suggests), or make a few discs or short, wide, cylinders shaped to be held in the chuck jaws for this purpose. If you have round discs of different diameters that fit the "wood-worm" or screw chuck adapter that comes with most chucks, you can quickly spin one on that's a bit smaller than the rim of the bowl (the disc tightens up against the jaw faces), set the bowl over this disc, bring up the tailstock, and away you go.
5. The bowl is held very securely in this way, and if the support inside the bowl is wide enough, you should be able to finish turn, sand and polish the outside, as well as true up and re-shape the tenon for gripping later, before going to the inside of the bowl.
6. Grip your now-perfectly-shaped tenon, and finish turn, sand and polish the interior.
7. Reverse turn again with the disc of wood and the tail center -- this time being careful to pad the contact area between the disc and the interior of the bowl -- and shape the final foot, removing evidence of chuck jaws, and carefully turning the bottom of the foot down to a little nub, which you can remove off the lathe.
8. With practice, a long bevel, and a steady hand, you can get the little nub down to less than 1/4", and on smaller pieces with good balance, down to about 1/8". Thus nub is snapped off or cut away off the lathe, and touched up with a little hand sanding.
8. A nice trick to learn -- and a nice little show-off step a lot of experienced demonstrators use -- is to turn the nub away completely, holding the bowl up against the wood disc with steady pressure from the bevel of the tool! It helps to have a long bevel (pointy tool) on a detail or spindle gouge, fairly low RPM's, and even a slightly convex bevel so the wood is burnished, and not scraped up by the pressure from the bevel against the foot. You need to be able to turn the lathe off with the hand that's not holding the gouge for this to work!
If you get used to starting bowls between centers, you'll always have a little index mark to use when re-chucking later. The rest just takes practice. It may seem like a lot of steps, but they go quickly and naturally once you turn the various disc sizes you need. If this process seems too slow, this is where production turners and those with more money than patience (IMHO ;) ) use a vacuum chuck. They are incredibly handy, but not required to do this sort of reverse turning.
Safe spinning,
Brad Vietje
Newbury, VT
Mike Stafford
Mike Stafford
Henry there are as many ways to accomplish your objective as you have money to spend.
I made a large double thickness MDF disc upon which I glued several layers of carpet padding. After drying I aligned the bowl with the live center and pressed the warped bowl into the padded surface of the MDF disc. Mine was sized to fit on a Nova 3000 very similar to the one you have.... :D
I trued up the tenon or chuck recess and cleaned up as much of the exterior of the bowl as I could without cutting into my padding.
Then it was just a matter of regrippng the bottom with the chuck and finish turning the outside and inside.
Then to remove the tenon/chuck recess if they were not part of the design I used the padded disc and live center once again to remove the unwanted material as much as possible. Then it was just a matter of carving off whatever needed to be removed and sanding the spot where the live center point had rested.
In Jamie Donaldson's class at John C. Campbell one of the first things he has his students do is to turn a large cylinder with a crowned end that fits into the chuck jaws. Then you can glue on a piece of mouse pad or carpet padding and use that to drive your dried bowl. It works very well for truing the tenon or chuck recess as long as you have a mark from where the live center rested when you were roughing out the bowl. Cheap, easy to make and very effective.... ;)
Steve Kubien
Re: Jam chuck ...
Steve Kubien
I'm use a jamb chuck and re-true between centres.
For Mine:
George Guadiane
If it's a hollow form I put it back between centers - cone in the opening and live center in the hole I put in at the beginning. I re-true the tenon so that the opening is fairly well centered. That makes hollowing easier.
For natural edge bowls I use a large (inside) jamb chuck and the point to re-true the foot.
For regular bowls I use a flat chuck to get a "nearest true" center, re-true the tenon and go back to work.
Hope that helps.
G
for hollow forms...
GaryG in MD
...the classic is the Kirsten Kone. You can Google it and find lots of examples. One nice, home-made version can be seen on page 13-14 of the November 2011 issue of the Newsletter of the Capital Area Woodturners. ...Gary
Many thanks - Excellent answers.
Henry (Raleigh, NC)
Thanks, these ideas help a lot. My attempts have resulted in too many flying saucers (face shield in place, but no body armor!).
Excellent and comprehensive answers to a basic question. WC standards have certainly been adhered to! I'll have to dream up more questions.
Henry
