Angle grinder cutters
I had time to play with various angle grinder attachments for carving this weekend. clockwise from top left. Arbortec, Lancelot, 24 grit sandpaper, Holy Gallahad course, Kutzall medium, flap wheel from Lowes.
I place them in roughly aggressiveness order going clockwise from top left. The Arbortec and Lancelot are about the same as far as aggressive and dangerous. The rest are considerably less dangerous but of course not as aggressive.
You can cut grooves with the Arbortec and Lancelot. With the 24 grit and the think Holy Gallahad you can cut a somewhat widened groove. Groove cutting is the most dangerous technique. Use both hands and take light cuts and you'll be OK.
I have the medium Kutzall and it's not as aggressive as the Holy Gallahad but then the course Kutzall might be the same. The flapwheel from Lowes is inexpensive and does a decent job but clogs up and goes bad fairly quickly.
The 24 grit sandpaper is pretty effective, not any where near as dangerous as the Arborec and Lancelot, and is pretty inexpensive although you would have to do a long term test to see how the carbide cutters of the Arbortec hold up vs replacing sandpaper discs fairly often.
A really good way to go if your going to do a lot of carving is the mini Arbortec. It is much safer as far as controlling the cut and will reach into tighter places. It will still cut you badly so be careful and use both hands. It feels much much better from a control standpoint.
