ADVERTISE HERE - FREE TRIAL
Wednesday Turning Chat 1/25
Stuart Johnson
Should box lids be loose, pop fit or friction fit? Should they have a knob or finial? This week let's chat about your favorite way to fit lids and what type of handle you prefer.
See you Wednesday night at 9:30 eastern.
Re: Wednesday Turning Chat 1/25
Check out Raffan's article *LINK*
Here's what Richard had to say fifteen years ago. See if it resonates....
Raffan article, page 36
Note who the executive editor was...
I will probably be late if I make it at all so I'll give my 2 cents worth now. I like snug fitting lids on small boxes.These are boxes you can easily pick up and put in your hand. It takes 2 hands to open the box.
If it's larger, like the kind you will lift by the finial or knob, then I like a loose fitting lid. this way when a customer picks up the lid the box stays on the shelf. Larger boxes also tend to change shape with the seasons and the lid may not fit the same. there's nothing worse than picking up a box by it's lid and 2 seconds later the bottom releases and falls to the floor. This is also why I go with more of snap fit lid rather than an air pressure lid on the small boxes.
On my sewing kit lids I simply make the flange for the lid long and parallel to the sides. When you then make the lid this length along with the very slight friction fit keeps the air pressure inside and the lid won't come off until you pull it off. I make these same boxes for pills and I'm even considering making one for toothpickes.
Don't forget threaded lids. Threading is fun. I got a new miniature cutter from Bestwoodtools the other day and will start making some tiny boxes with threaded lids.
