THE WOODRAT IS BACK!
Photo resizing for Mac?
Dave Staeheli
I was attempting to post my first photo when I discovered that I do not have the ability to resize my photos to Woodcentral standards. The resizing software discused a couple of weeks ago all seem to be geared for windows. Anyone know of a good freeware program good for Mac?
Re: Photo resizing for Mac?
Peter Hyde
iPhoto on your Mac is free. Select photo and export. Select size in drop down menu. Then open the exported photo with Preview. Select "save as" and adjust size with slider.
Leo Cuellar
Leo Cuellar
You should also be able to resize directly with Preview. After you open an image file, depending on which OS version you are running, pick "save as" or "save a version" from the file menu.(you may get an intermediate box telling you the file is locked, would you like to duplicate. Do so then go back to the file menu & re-select 'save")
You should get a dialog box that will give you the option of changing the format and a "slider" control switch which will allow you to adjust the quality/size of the image.
Picking "save as" & renaming the file is the safer option for beginning as you are working with a copy of the file instead of the original. There are quite a few different options for manipulating an image with Preview. Don't be afraid to play around with a copy of an image :) Not great at this yet, but might be able to answer a few more questions if you have any.
Leo
George Taylor
George Taylor
I don't know if it is a better or worse method, but you can also export within iPhoto and just play with the the Size and quality to get a file that can be uploaded.
Thanks guys!
