Have a question? Ask Woody!
Accordianing Hollow Form Idea *LINK*
charlie belden
Had some resawing to do so I finally put the Laguna Tools Resaw King I bought on sale for $75 last year on my bandsaw. Got out my shop made, adjustable for blade drift", resaw fence and cut the first slice. Was amazed at how smooth the sawn face was - as smooth as the S4S board I resawed. And because the carbide teeth have almost no set, the kerf is narrower than the Wood Slicer I've used and the cutting action is smooth, even at a fairly high feed rate. Not quite like cutting butter, but . . .
You've probably seen the attached video or heard about the Bridge City JointMaker - and wiggle wood that can be made with it. So I'm thinking - WHAT IF . . .
Pieces turned green often deform in interesting ways. Wonder how an accoridaned hollow form would behave as the humidity changes?
accordian wood example video
Re: Accordianing Hollow Form Idea *LINK*
Tony Reynolds
Tony Reynolds
Don't know about the hollow form, but the JointMaker is pretty cool!
charlie belden
You did see the price, right?
Having seen it cut the curved apron parts for a demilune table, it does what it's advertised to do. Like the Festool DOMINO loose tenon mortising unit, it's a tool looking for problems to solve.
Because it works at human hands speed, it seems safer to use. And the precision it brings is pretty good too. The depth of cut however is limited.
I do have concerns about using a bandsaw, even with the Resaw King blade/band, on a hollow form, making cuts as close together as I think would be required to permit the piece to accordian.
charlie I wonder how the V cut and grooves they cut first affect the movement. If I'm correct that's what gives it the left and right flex ability. The V cut gave it a place for the bearings to roll but may affect the flex as well.
The curve flex is of course the slots. I've done the slot cutting thing on a larger scale to make a rounds piece of molding to repair an antique desk.
Cutting slots with the hollow vessel glued to a flat piece sitting on the table would be fairly easy. Cutting slots the way you drew them would be pretty scary. Possibly cut the vessel in half and glue that to a jig and do each half seperately.
charlie belden
The idea to do the cutting on HALF of the HF, temporily attached to a flat board would be safer. A paper joint in the orginal blank would make parting into two halves fairly easy. Leaving the walls thick - 1/4" to 3/8" would provide some strength. The order of the cuts would also be important, probably starting in the center and working outward so the wood to be sliced next would have some support on one side.
Lyle Jamieson
wont work the same
Lyle Jamieson
Sorry to throw cold water on the idea. What hapens when the cuts are at the mouth opening. Each cut will be unattached at the mouth and only attached at the base of the vessel. This would leave small strips of wood unsupported. The accordion effect would only work where there is a bridge connecting the opposing sides and opposing ends.
Charlie, have you checked out some .....
JamieDonaldson
...of Christian Burchard's recent "sawed into layers" work?
Re: wont work the same
charlie belden
Gonna have to think about that one. Easy solution would be to NOT make the cuts at the neck/opening. Might be easier to just make the From The Top Cuts and see how the parts move with changes in moisture.
I'm always looking for ways to get actual movement in pieces. This idea could add actual movement, though the rate of change would probably be slow.
David Belser, a Master of Wild Hare Ideas, suggested making the cuts in the blank, encapsulating the cut blank in wax, turning the HF then melting out the remaining wax afterwards.
Another example of If You Can Think It - It Can Probably Be Done.
Also another example of the advantages to sharing ideas. More eyes on a problem - the more likely the problem will be solved, often in several different ways.
I have seen his sliced pieces
charlie belden
but they've been pretty abstract, at least the ones I've seen. This idea is after a piece that is recognizable as a turned form, but with a very different look and one that lets nature have a semi-dynamic hand in it over time. If it would hold up to some handling it could be fun to play with.
Charlie the Biggest problem I see is going to be the weakness of the grain at certain points around the piece. Perhaps a segmented piece would be better because you could orient the grain at a certain point for the strongest position. That hit me when Lyle posted his response.
Re: wooden slinky???
Lyle Jamieson
Re: Charlie, have you checked out some .....
Lyle Jamieson
How about Ron Gertons work that he cuts hollow forms with curved line slices and glues them back together...amazing. Look at rongerton.com in the desegmented vessels menu
A-Phreakin-Amazing!
charlie belden
Ron's pieces are just plain a-phreakin-amazing. His "desegmented" pieces border on pure mathematics - and I mean that in a very GOOD way. The technical skills required to make his pieces stretches what's possible. The fact that he can conceive of such pieces, then execute them - so really well - blows me away. My Wild Hare Ideas seem like tinker-toys things while his ideas are more from NASA or Sandia Labs.
Having grown up in the Panama Canal Zone, the leaf cutter ants struck a chord with me. And having done a lot of lost wax casting, albeit at a jewelry scale, I can really appreciate his castings - and patinas. That fact that he has such a command of wood and metal - and uses the combination to create such fascinating pieces is wonderful.
Thank you for pointing me to ron's site. It's definitely a Keeper.
