another question.. tapered jam chuck
darrin hill
so the ladies want matching earrings to go with their pendants, and I've glued a bunch of blocks together and turned them into a cylinder. I then used a forster bit and bored out the wow, and then cut a bunch of doughnuts for loop earrings.. however one side is finished and the other needs to be turned..
because i got a book at swat that shows how to make jewelry and this is how they do some of it..
i've never made a jam chuck before, so just wanted to know if i make a taper on a block of wood and push a loop onto the cone, will it stick enough for me to finish the backside? i know that when you make a jam chuck for a bowl, you make it snug, but don't know if i have to do that for each loop... that would be hard cause I'm trying to crank them out for a bunch of people and having to make a chuck for each loop would prob not work..
Re: another question.. tapered jam chuck
Darrin You could use a tiny bit of double stick tape to hold it on the jam chuck if it didn't fit well enough. When my students made earrings at the Folkschool we just sanded the back side.
darrin hill
cool.... but a tapered/cone chuck is the general theory, right?
What I have them do is to make a tenon larger than you need. Then make the front part tapered so it's smaller than the hole by a hair. Put it on and twist the chuck. This will make a mark on the tenon to show you the size. Now make the taper very gradual so the earing will fit.
The problem with something the size of an earring is that you can break it with a taper if you force it on. So ideally it should fit snug just as it bottoms out on the shoulder. That's really hard to do which is why I pulled out the double stick tape.
Hot glue will also work if you've already applied finish to the other side. The hot glue won't stick real well to the finish and is easy to get off by peeling or using alcohol. You don't need a strong bond, just enough to keep it from spinning.
Keith Tompkins
Keith Tompkins
Hi Darrin. I use a taper all the time. The odd thing about it is: when you shorten the taper, the jam chuck increases in diameter! Makes it nice during a demo, when you don't have time to fiddle around. Too loose....just take a bit off the end of the jam chuck.
