I would like to make some 12" to 18" x 1" dia metal tool handles. I searched the archives with little luck.
The web yielded little direct info; some information by Cindy Drozda and a video by Cappin Eddie. Anyone have a good technique on making metal tool handles?
Do they have to be pretty or just usable? I make the usable version (not much to look at). If you purchase un-seamed dimensional pipe steel (expensive) you can slide a 3/4" pipe into a 1" and so on to get down to the size gouge you want to insert. I just use the seamed variety (fairly cheap) and use whatever I need to insert into the pipe to get it to the size needed. That may be a piece of conduit or the next size down seamed pipe (lightly ground to fit) or etc. Start by cutting the 1" pipe to the length you want for the handle. Lightly grind the edges so they are not sharp. Then cut a 2 to 3 inch piece of whatever you are going to use for a reducer to get to your gouge size. Insert that into the pipe end (it should fit snug whatever you use). Drill two holes, one about 1/2" from the end and the other about 1 3/4" from the end. Tap them to accommodate the set screws you are going to use to hold the gouge. Make sure your screws go through the insert you used. Then slide a braided plastic/rubber pipe over the steel only up to where the sets screws are so you have access to them (using liquid soap helps with this operation). If you have a 3/4" gouge and need the inside of the 1" pipe to accommodate it then put a short sleeve on the outside of the 1" pipe (I used the next size up pipe for this on my two 3/4" gouges and ground the edges so they were not sharp).
Just a side note. I checked the weight online of seamed steel versus solid aluminum which most aluminum handles seem to be made of. Seamed steel is actually lighter than the aluminum per unit measure. Steel handles work great for most applications but I find that for the finesse or fine cuts that wood handles give me a better feel on the cut (most of my gouges have steel handles though). Final note is you can make many handles for what one costs from handle vendors. The process is fun - enjoy your new handles.
FWIW, there is an Industrial Metal Supply in Kearney Mesa or Mira Mesa that will have what you need. Or Google IMS for the location. I've been there, but it has been beyond the range of my diminishing memory.
I have a couple of those handles and find them cold, physically and esthetically. But each to his own. Live would be too dull if we each were alike.
A buddy of mine picked up some round aluminum bar that he simply mounted in his wood lathe chuck and drilled for the tool size. Cross drill a small hole and tap it for a set screw, and you are functionally done.
It's possible to get much more complicated that that with decoration, but it's just a handle, also known as "the hammer you always have in your hand"... so it's your call.
Phil It's easy to buy round hollow aluminum stock. You can also buy solid rod and then cut off pieces and make inserts for both ends of the hollow stock. These are easy to turn on a wood lathe and probably easier to drill since they would be quite short.
Thanks John. What is the best way to hold the solid insert inside the tubing? It seems the tubing is too thin for the set screws to capture effectively.
I just epoxy the insert in. the tubing I purchased has a wall thickness of about 3/16" or so. I have also used PVC pipe for the handle and made either aluminum or wood inserts to go in it. Mike Hunter sells some aluminum inserts that work in PVC. They might work in some aluminum handles. I'll bet he would know.
With the exception of possibly adding metal shot to the handles to make them heavier and deaden (?) vibration, turning handles can be made extremely easily like Steve suggests from 1" rod stock of 6061 Aluminum. This is fairly inexpensive to buy locally, fairly strong structurally, and light enough such that longer handles can be made if desired, without adding too much weight to cause them to become fatiguing to use over long periods of time. Furthermore, the aluminum drills and taps easily. I have made handles of several lengths with 1/4", 3/8", 1/2", and 5/8" holes for gouges, etc. These are about the easiest changeable insert handles you can make - even easier, IMHO, than turned wood handles.
For comfort, you might consider using some 1" ID plastic hose material slipped over the handle, or for more of a cushioning effect, go to a bicycle shop and get some handlebar grip replacements that slide nicely onto the 1" aluminum handle shaft.
You can make handles very easily without the need to cut and fit plugs, etc.
I have made seven such handles (four from 1" aluminum, and three shorter ones from 3/4" rod... for some d-way beading tools).
Drilling was easy on the lathe. I used carbide tools to chamfer the ends, but a file would have done fine.
I made them double ended (a different size hole in each end) making them more versatile as I add gear. I found plastic end caps for the end currently not in use.
I used set screws that were the same size as other items in the shop, so it's easy to reach for the right T-wrench.
Finally, I found clear braided PVC tubing that works well as a sheath (simply wet the tubing and it slid over the aluminum rod with minor coercing.
They don't, but in this instance I'm using a Oneway double ended gouge and it needs to go inside the handle. I like the idea of solid stock as well. Thanks for your suggestion.
Personally I prefer wooden handles for the balance and warmth. I have quite a few metal handles all of them hollow. Some steel, some aluminum, some rubber coated and some not. I find the not coated ones to be really cold in the winter. I do like the shot filled ones for roughing out of round blanks.
I like being able to store the tool blade in the handle for traveling but I only have a few that will allow that.
I too prefer the feel of wood, especially in the winter.
However, I also like the convenience of easily being able to remove the gouge from the handle for sharpening or tool swap.
So I've used OneWay Thread-Lok adapters on a few of my handles... giving the best of both worlds.
Each adapter has a tapered thread inside that screw onto a tapered tenon at the end of the wooden handle. Two set screws lock the gouge into the adapter.
I have used those inserts that Mike sell in wooden handles to great effect. I just drilled an appropriately sized hole and glued the insert in with epoxy.
The wood is warmer to me than the metal handles but I do work in an unheated shop...I am also a sissy when it comes to cold.
Why not get a long drill bit and drill a 10" long hole that fits your double ended tool? A set screw in wood will hold just fine, and wrap the end in a slightly larger ferrule?
Drill the hole in sections to make sure you start out straight, and clear chips often. I'd mount the drill in my headstock and use the tailstock to advance the handle 1" at a time until I was deep enough.
If you are worried about it breaking, drill it larger and line the hole with a steel/copper tube and make the inside diameter the diameter you want to hold.
