Different type of mirror
I am planning on taking my mirrors to the next level. This is an experiment in tension. The bottom is Eucalyptus burl and the top is Birdseye maple. Everything is turned except the carved portion of the top of the Eucalyptus. If you remember Keith's tutorial on turn a square block you'll know how.
Re: Different type of mirror
Steve Kubien
Wonderful
Steve Kubien
John, this may be my favourite of your works. I'm speechless.
COOL mirror
jerry bennett
John, I had to jump in here. This is great!!!
BarbS
Oh my Yes. Great idea!
Tony Reynolds
Pretty cool John!
Re: Oh my Yes. Great idea!
outrageous!
GaryG in MD
I'm with Steve on this one, John.
This really strikes my fancy.
The whole thing is a visual feast and to know that the base is a square turning makes it just that much better!
The possibilities are endless.
This may end up being your signature work.
More, more!!! ...Gary
Don Leydens
Re: outrageous!
Don Leydens
Excellent idea and well executed, John. I really like this.
Far Out!
George Van Beynen
Great Idea John. The extension of the mirror sure grabs my attention. Well executed!
Lyle Jamieson
Whats next?
Lyle Jamieson
Nice work!! Whats the next generation? How about a set of pins holding an adjustable, swiveling mirror insert??
Re: Whats next?
Lyle I just designed a unique swiveling action for the bottom of a mirror this morning. We'll have to see if it works but I think it will. I have a much more interesting one in the design phase and it needs a swiveling bottom mount.
Lyle Jamieson
Re: Whats next?
Lyle Jamieson
I figured you would be way ahead of me
Keith Tompkins
Keith Tompkins
Hi John, Good stuff! However....I have a challenge for you. What if you turned another cube, then made a round insert for the mirror, then parted it off. You would have enough stock for a couple of more mirrors, and end up with a square mirror and a square base..all turned on the lathe. The only problem is, nobody will believe you it was all turned on the lathe..Don't ask how I know this.. :D
Simple Swivel?
charlie belden
With a hand mirror, you bring the mirror to your face. But that requires one hand to hold the mirror.
With a fixed mirror, you bring your face to the mirror and both hands are free.
With a fixed pedestal mirror, your hands are free, but you've still got to bring your face to it - at a specific location.
With a swiveled pedestal mirror you have a compromise. Your hands are free, you still have to bring your face to it, but you AND the mirror can each accomodate the other, the mirror being able to tilt over some range of motion and then remain in a desired postion.
Getting the swiveling option is easy - ball and socket joint will do that. Getting the swiveling option - when you want it - then fixing it in a desired postion - is a bit more complicated. That would rrequire some threading to be able to lock things in a desired position.
One possible solution would use friction and gravity to help out.
Here's an idea that might work - and would go with the look of this piece as it it now. To get the center of gravity of the moveable part (the mirror and its upright component), you'd need to add some internal weighta the bottom. Some hollowing of the rouned bottom - then filled with steel shot or lead - might work.
Here's the idea. You could move the mirror and upright to a desired pistion and let go. Gravity and friction would keep it there.
Just throwing in an idea to consider.
