Does your head stock line up
Terry Scott
I was emailed today and was asked to post my pour attempt at an article as many on wc dont look at wow and with the number of responses maybe of interest
Here goes
Before I start using any lathe I always check if the head stock lines up with the tailstock
especially when I am doing my winged vessels as when I flip the work over I have to have the piece running true or the wings end up differnt thicknesses.
Have you found when remounting a lid on a box for example that when you bring up the tail stock the live center cuts in a figure of eight.
Or flips the lid out of the jamb chuck.
Finials are hard to get right as you end up with of center turning at the point
Many turners that Ive asked have had no idea if their lathe is in alignment or not, they just think it should be.
I havnt found a swivel head lathe yet that locks back in line correctly.
Even on my stubby 1000 I was surprised that it was out (turned out id bolted it down and racked the frame. Yes I laid the floor
Ive been trying to find an article on aligning the head stock and tail stock without success.
So Ill give it a go Please add to this if you see anything I have missed
This article is also on my web site www.timberlywoodturning.co.nz
Thanks to Dick Veitch for the pictures
This is how I go about it and know carry a Acruline with me when I travel
I have no association with Nova but have found this system the best method
Happy to learn of other methods you may use
Nova Acruline Lathe Alignment System
DOUBLE ENDED No2 MORSE TAPER
This item is designed to be fitted into the NOVA lathe's tailstock and headstock spindles to bring back the alignment for those lathes with adjustable tailstocks or headstocks.
Many turners tell me they are having trouble turning certain items because they have problems lining up their lathe's headstock and tailstock.
The Acruline is what you need.
Are you finding that you are having trouble drilling straight, or that when you bring the tailstock up to your work the live centre forces the work to one side or cuts a figure of eight in the work?
Bringing up the two points of your spur centre and drive centre is not accurate as one mm out will cause a whipping action on longer spindle work; or both the head and tail may be out of line but still meeting at these points.
To use the Acruline:
1. Loosen the headstock so it rotates freely
2. Place the Acruline firmly in the tailstock
3. Bring the tail stock up so the tip of the Acuruline is just inside the opening of the head stock spindle
4. Lock the tailstock to the bed
5. Wind in the quill with the hand wheel until the morse taper seats firmly into the head stock
6. Tighten the headstock
7. Remove the Acruline
You can further check the headstock alignment by holding a long bit of wood in a chuck.
Do not bring the tailstock into contact with this wood.
Then rotate the wood gently and make a pencil mark at the centre of rotation at the tailstock end of the wood. Bring the tailstock with a live centre in it close to the pencil mark and check the alignment. This assumes that the tailstock is correctly aligned and checks headstock alignment only.
Bringing up the tail stock and headstock with spur and drive is not very accurate as the tapered points play tricks on the eyes.
Remember being 1mm out when the tail stock and head stock are brought together means 10mm out over a meter of bed.
Cheers
Terry
