Making a "Square Convex Pillow" Procedure
charlie belden
What follows are Notes To Myself. I'll use them IF I ever get around to actually
making a Square Convex Pillow. They will surely be revised after I've tried to
make one - or thought through the process more thoroughly. As is, the notes
can get me started - and maybe get someone else started.
Step 1: Cut the four 2x2x4 components
Step 2: On each of two components, glue newspaper to two adjacent sides (RED & Blue).
Step 3: Glue pairs of components together at their "paper joints"
Step 4: Glue the two pairs of components together at their "paper joints" to make your blank
Step 5a: With a forstner bit, drill a hole in the top of the blank about 1" deep. This will be the
opening of your "hollow form pillow". The hollowing will be done later, again with a forstnet bit
Step 5b: On the top of your blank pencil in the arc that you want your "pillow faces" to have as
shown in yellow
Step 5c: Bandsaw off the corners of the blank
Step 6: Between centers, turn a barrel shape. Make a card stock template of the profile you're
after and use it to check your progress. You'll be turning TWO of these barrel shapes and the
closer their profiles are, the less work you'll have later.
Step 7: Remove your "barrel" and "hollow" it with a forstner bit in a drill press. You want to leave
yourself about 1/4" of "meat" at the barrel's inside diameter.
Step 8: Using a scalpel, safety edged razor blade or a utility knife, at the hole in the side of the
barrel, at the paper joints, begin opening the paper joints. Then, using a dull knife, split the
componets apart. A dowel, turned a little smaller than the diameter of the forstner bit used to do
the "hollowinig", placed in the barrel will reduce the likelyhood of breaking anything while you're
separating the parts.
Step 9: CAREFULLY sand off any paper from the edges of the two parts you will use. DO NOT
get overzealous while sanding - you want to get rid of the paper NOT THE WOOD. Removing
wood will mean parts won't fit together nicely and sloppy joints WILL SHOW.
Repeat Steps 1 throgh 9 to make the other two parts needed.
Step 10: Glue the four components together using a minimum amount of glue. You want to avoid
glue squeeze out on the outside of the piece. If you do get some glue squeeze out, wait 'til it's
almost dry and carefully pop it off. DO NOT wipe it off with a damp paper towel - if you plan on
applying a finish to the piece, especially if you plan on staining or dying the piece. Wood with glue
on it doesn't finish the same as bare wood.
Because the bottom of the piece is curved, it can rock. If you want to have it sit upright, sand a
flat area on the bottom. You could probably sand a "flat" to have the piece sit at any shallow angle
you desire.
As always, questions, comments and suggestions on how to improve this info are welcomed.
Re: Making a "Square Convex Pillow" Procedure
Charlie I didn't have time to build one today but I did play a little bit. Drilling it is going to be challenging. Put a band clamp around it or it will blow apart the paper joints. This is from personal experience. Holding something round like that will be challenging as well.
I was hoping to have time to make one today. That didn't happen. I did turn some pieces and played with drilling them but didn't have time to glue up blanks to play with.
I did learn a new way to sharpen dull forestner style bits using a 1" strip sander.
charlie belden
All the turning would be done between centers, no chucking needed.
Drilling the hole that will be the opening in the top of the final hollow form can be done while the paper joined blank is still got parallel flat faces and can be done on a drill press. I'd start that hole with the forstner bit of the ized hole I wanted, then use smaller forstner bits progressively to do that hole.
The forstner bit hole through the turned piece along its axis can also be done at the drill press after the blank is turned assuming that the ends sof the "barrel shape" are turned flat. Again, progressive sized forstner bits would probably be wise to minimize the stress on the paper joints. Your idea of band clamping is a good idea.
The fun challenge may be the glueing the four parts together, and not have anything slip or slide out of alignment.
Look foreward to what you come up with.
Charlie I was trying to think of ways to do this while I was waking up. Yea I know I think about turning in my sleep. I'm thinking of this as an ornament ball so it's not very big, at least for my first ones.
After it's been turned make a jam chuck out of a limb segment. Hollow out the limb to fit the blank. Cut slots in the limb to make it flexible. Put the "Pillow" in and then band clamp the outside of the jam chuck. That would both hold it and keep it from exploding in one piece. It could then be drilled on the lathe, or in fact you could simply hollow it with hollowing tools.
I agree the second glue up is going to be challenging. I would put contrasting veneer between each segment. Probably glue up 2 halves so you could flatten that surface in case anything slips. You could also trim the excess veneer at this stage. Then glue those pairs into the final piece.
It sucks I have to work the next 2 evenings or I would get started on this.
Lloyd in Mississauga
instead of making 2 that will end up being the same size, could you return the "ends" of the barrel by holding it between cup centers on the rounded sides?
Shape the center to end within the hole, and the sides should arc to the seams.
You may have just as much luck reshaping as you would making a second the same size and shape.
Lloyd
charlie belden
I think a template would help making the second barrel profile close enough to the first.
Turning the barrel shape and then rotating the blank and turnnig the ends would be easier, but hollowing would be a bit trickier and you couldn't get into the corners like you do with this turn, split apart and reglue the selected parts.
This drilling first, splitting things apart and glueing parts back together should be within the abilities of an advance novice or an intermediate turner.
