Removing Sanding Discs
Doug Reynolds in Seattle
I am new to segmented turning and just got a 12" disc sander. Now I need to know the best/easiest way to remove the old and warn disc. I was thinking of using a heat gun but, was afraid it may cause the metal disc to warp. Other than a putty knife and hard work, are there better ways to remove the disc?
Re: Removing Sanding Discs
mjonesrdg
I use a heat gun applied directly to the face (gritty) side. The amount of heat required to soften the adhesive is way, way, too little to warp your backing disc.
I used lacquer thinner. Get an edge loose with putty knife just a crack and drizzle a little in and peal it off. (may take more than one drizzle.) Then used more on a rag to clean up the residue. Have not tried a heat gun, but no that I am a proud owner of one I may.
Rob Wallace
Be careful with lacquer thinner!!
Rob Wallace
Just a warning about using lacquer thinner - unlike mineral spirits ("paint thinner") which I would try first, lacquer thinner is a more "powerful" solvent, and in many cases will soften and/or remove paint from your machinery or other surfaces it contacts. (Don't ask me how I know that!). You do not want to damage your machinery or other surrounding surfaces during the disk removal process.
Therefore, if you do choose to drizzle lacquer thinner onto your worn disk, you should be very careful about drips and any unintended run-off from your removal operation. I use a heat gun to soften the adhesive as an aid to peeling off the old disc, and then use mineral spirits to clean any residual adhesive remaining on the metal surface. I suppose for stubborn adhesive, lacquer thinner could be used, but I would first apply it to a cloth to avoid drips or spills of the solvent.
The careful use of a heat gun or mineral spirits are much better choices, in my opinion.
Rob Wallace
second what Rob says DAMHK
Re: Removing Sanding Discs *LINK*
Stuart Johnson
You shouldn't need to do anymore than start it and then pull it off. If you have a problem use a plastic putty knife to get it started. A few easy steps:
1. cut the backing on the new disc about 1/3 and peel off. Set the new one aside.
2. pull down the old and slip the piece of backing behind it.
3. rotate the disc and pull the old paper off.
4. slide the new paper with the 2/3 backing still and to the bottom.
5. press the top on.
6. rotate the disk and pull off the rest of the backing.
7. use a J roller to firmly set the paper.
If any adhesive sticks to the disc use Strypeze varnish remover to clean it off between step 3 and 4 . It can be bought at ACE Hardware or Sherwin Williams.
Leaving the backing behind the old paper when removing prevents it from sticking as you rotate the disc to pull it off. That left on the new disc allows you to position the new paper without it sticking when before you are ready.
Strypeeze Varnish Remover
Dale Jablonski
dale jablonski
I've never had a problem with my heat gun, no need for more chemicals. It doesn't take that long to soften and then I use the putty knife to get it started and off it peels.
steve worcester
If you actually want to remove the adhesive, use Bestine, rubber cement thinner.
