Veritas - Innovation in Tools
Latest Bowl
Latest Bowl
Brian McKearney
Latest Bowl
Brian McKearney
Here's a bowl that I turned on New Years Day. It was turned from a Beech log that a coworker gave to me back in 2006. This is the first bowl thing that I've made from Beech, so it was interesting because it is a very tight grained wood. Pretty nice wood, but lots of very fine sanding dust.
Finished with several coats of Tried and True followed by a few light coats of General Salad Bowl Finish.
Brian
Re: Latest Bowl
Re: Latest Bowl
jake Niedling
I like the shape, the top edge and band around the outside. Keep up the good work.
Re: Latest Bowl
I agree with Jake...
GaryG in MD
Nice shape.
How big is it? ...Gary
Re: Latest Bowl
Brian McKearney
Re: Latest Bowl
Brian McKearney
Sorry - forgot to add the dimensions. This one was the core from a larger blank and is 9" x 2 1/2". Can't wait to get into the larger one, which was closer to 15"-16" diameter.
Re: Latest Bowl
Re: Latest Bowl
Brian That's a very nice bowl. Great shape and detail. I have a question. Why follow the tried and true with salad bowl finish. Both are finishes. I wouldn't think you would need both but I'm willing to learn. Actually I do learn something new everyday from all you guys.
Re: Latest Bowl
Re: Latest Bowl
Hal Taylor
Very nice bowl indeed. Love the shape and band.
Re: Latest Bowl
Brian McKearney
Re: Latest Bowl
Brian McKearney
No specific reason to follow Tried and True with General Salad Bowl Finish other than the fact that I just wasn't satisfied with the first finish.
I applied several coats of Tried and True and it came out OK, but on the Beech I was getting some shiny spots and some dull spots. After knocking down the shine with fine steel wool, the Beech just looked unfinished even though it had 5+ coats of finish on it. With the tight grain, the Beech just didn't soak up all that much oil.
So I followed it up with 3 very thin coats of salad bowl finish which gave it a pretty glossy look and I was finally satisfied.
Brian
Re: Latest Bowl
Phil Stivers
Re: Latest Bowl
Phil Stivers
Very nice bowl indeed! I have found that a bowl created for utility is better suited to a "non shiny" finish. I save the shiny finishes for ornamental/decorative bowls only. A shiny utility bowl will quickly lose it's shine when washed. I believe it is better to put a walnut oil to other non-shine finish on bowls meant to be used for food (treenware).
You have a beautiful shape; let it speak for itself. In the words of the great Mel Brooks (sort of), "Shine!? we don't need no stinkin' shine!" ;-)
Re: Latest Bowl
Thanks, been there done that.
