Another Paper Joint Possibility
charlie belden
While I can admire and appreciate and interesting segmented turning, I can't imagine myself ever doing one. Too many parts, each having to be cut at very specific sizes and angles. to say nothing of all that glueing, and the possibilities, nay - the likelyhood - that one or more of those pieces will move just enough to screw up the end results.
Inspired by David Springette's book, and his use of paper glue joints, I started playing with ideas for "square pillows" - hollow square pillows. As long as your four blanks have a minimum of three adjacent flat planes, each intersectioing at 90 degrees to the other - or others - you're good to go. Oh, the paper joints between the four parts making up the blank must be 45 degrees to the centerline axis of the lathe.
Turn two straight cylinders or a concave cylinders or convex cylinders. The profiles and size should be pretty close, the closer the better. They don't even have to be hollowed out, but it's more interesting if they are. Picking up a wooden pillow to look at it - and discovering that it's much lighter than you thought it would be (because it's hollowed out and only 1/10th of the wood you thought was in it - is.) would be a nice surprise. (I like surprises - except if they involve explosions).
So here's a pillow with Convex Faces, one with Concave Faces and one with three Convex faces - and one Concave Face. Simple. I can turn a cove or a bead or a flat - and can do two pretty much the same. Turn them, split apart on the paper joints and glue two parts of each turning together. And if I want to do hollowing, a forstner bit will do THAT in short order, with no muss, no fuss and no sweat,
Give you any ideas?
Care to share it / them?
