Cherry Vessel
Cherry Vessel
Tony Reynolds
Cherry Vessel
Tony Reynolds
This vessel is made from a piece of figured cherry that I oxidized and finished with an oil finish. It's 8" in diameter. Not sure if it's the camera angle or what but it looks plumper in the photo than looking at it from across the room. The finial is also cherry ebonized. Comments etc always welcome.
Re: Cherry Vessel
Re: Cherry Vessel
jake Niedling
Tony - well done. If you look at the outside edge of the bowl you can see a nice curve. The line across it I think comes from your lighting, giving it a shadow. Did you put a finish on the finial, it looks like it has a flat finishes compared to the vessel? What did you use to ebonize the finial with? leather dye? Thanks for the pictures.
Re: Cherry Vessel
Tony Reynolds
Re: Cherry Vessel
Tony Reynolds
Thanks Jake. Yes the line is a reflection. The finial is ebonized with Higgins India ink and just sanded with 1500. It leaves a nice matte finish with no shine. Thanks for taking a look.
Tony
Re: Cherry Vessel
You've been hollowing up a storm!
GaryG in MD
I really like the form and the way the finial looks on it.
That's not an easy thing to accomplish.
What do you mean when you say you "oxidized" it?
You're giving me the urge to do some hollowing. ...Gary
Re: Cherry Vessel
Tony Reynolds
Re: You've been hollowing up a storm!
Tony Reynolds
Thanks Gary. There are several ways to oxidize cherry. Sitting it out in the sun will do it over time, but it takes a longggg time. I guess you can use lye as well but I haven't tried it.
I use a weak solution of water and potassium dichromate. I've used it for years on cherry furniture I've made and it looks like 100 year old cherry instantaneously. You need to raise the grain first and sand it back as the oxidizer would raise the grain and you don't want to sand it after using it.
You need to use the proper precautions when dealing with the potassium dichromate as it is very toxic. This includes rubber gloves and eye protection. You don't want to get this stuff on your skin. With that said, I find the results of using it worth the hassle. If you want more info on the stuff just Google "potassium dichromate wood" and hundreds of articles are available.
Thanks for stopping by and taking a look.
Tony
Re: Cherry Vessel
Re: Cherry Vessel
Randy Gleckler
Nice work Tony, Love the design... very fluid
Re: Cherry Vessel
Thanks, Tony.  Good info.
