REAL MILK PAINT
Tool rest query
Tool rest query
Tool rest query
Chuck Engstrom
Hi folks -- Does anyone recognize this toolrest assembly and know who makes it? A friend would like to find one constructed this way. (Photo seems to display here turned 90 degrees.)
Thanks --
Chuck
Re: Tool rest query
Bill Blasic
Re: Tool rest query
Bill Blasic
Looks like Randy Privett's from Monster Tools.
Bill
Re: Tool rest query
you might also look at the Bestwoodtools rests *LINK*
The bestwoodtool rests are made from a special NASA grade alloy that reduces vibration. The Brass collar is also not your standard brass and was designed for low vibration.
I have several but my favorite rests now are the Robust tool rests.
http://bestwoodtools.stores.yahoo.net/tbarmodtools.html
Re: Tool rest query
Re: Tool rest query
Chuck Engstrom
Thanks very much John & Bill. Bestwood was my first thought and I sent them an inquiry, but they said they didn't recognize it. I just went to Monster Tools and it does appear to be their product, so I will point my friend in that direction.
--chuck
Re: Tool rest query
Keith Tompkins
Re: Tool rest query
Keith Tompkins
HI Chuck, I'm not so fond of this type of rest after having an accident involving one...I was turning a square four-legged hollow form (as Ruth says, I can't turn regular) when the curved rest began to move; the threads that secured it to the post had loostened up. The rest swung into the legs, shearing them off, and my detail gouge ended up stuck in my palm. It happened so fast, I could't react in time. I had a local shop weld it into one solid unit.
Re: Tool rest query
Re: Tool rest query
I've heard of that happening but I've had my 2 bestwoodtools rests for 7 or 8 years now and never had it happen. There is an aftermarket brand out there. Was it that one. Not saying they couldn't come loose but I use mine hard and they have held up well.
Obviously the Monster tool rest will not do undo like that.
Re: Tool rest query
Keith Tompkins
Re: Tool rest query
Keith Tompkins
Hey John, Yep, it was. Probably my own fault for not checking from time to time if it was tightened. Won't come loose again :D
Re: Tool rest query
Rob Wallace
I'm glad it was only the vessel's legs...
Rob Wallace
...that got sheared-off and not some distal appendage of yours! :O
I ONCE had a Bestwood tool rest loosen while in use, and I immediately took all three of mine, cleaned the threads (inside and outside threads) well with mineral spirits, dried thoroughly, and applied a liberal amount of Loctite to the threads before tightening them back together. That was at least 5 years ago, without any similar kind of loosening.
Easy fix to that problem!
Rob
Re: Tool rest query
Lyle Jamieson
Re: I'm glad it was only the vessel's legs...
Lyle Jamieson
I do not like round tool rests of any kind. Two out of the four cuts we do have the handle down. With the handle down the round tool rest pushes the support away from the turned surface. I would rather have the support as close to my work as possible. The Robust, Oneway, Jamieson tool rests are the best for keeping support up close.
