Just starting turning again after a fair hiatis and was wondering what the preferred method of cutting segments for segmented turnings? Way back when I cut them on a table saw, but I have some tell me they cut theirs on a sliding cross cut miter saw. My old table saw sled is history and need to gear up again.
I prefer my mitre saw for cutting segments. You might check out the segmenting chapter of AAW (segmentedwoodturners.org) for more information or Malcolm Tippets website.
there was just a post on this on the segmented woodturners forum and it was split about evenly between the two. There is a 3rd technique which is cutting the segments close to size on the bandsaw and then sanding them to perfection. that is usually used when you need to orient the grain a certain way to keep a ring from self destructing later. some people also use the disc sander after cutting on the miter or table saw to clean up any saw marks and to make the pieces more accurate.
One way to really shorten the learning cycle for segmented turning is to buy a copy of Malcolm Tibbits's book, "The Art of Segmented Turning." I followed his instructions very carefully and had great results.
This past year I took a segmented turning class from Malcolm Tibbetts at Marc Adams School of Woodworking. Malcolm said he used a Festool Kaypex sliding compound miter saw to cut segments and "rarely" needed to sand to finished dimension.
