another sharpening video *LINK*
mjonesrdg
I had not seen this system demo'd before. Interesting!
WWGOA Worksharp
mjonesrdg
WWGOA Worksharp
I have a couple of questions
For those who have one of these. I would think the outer edge of the wheel would be more aggressive than the inner part because of surface speed. This probably isn't a problem on smaller tools but would seem like it might leave the edge non square on 2" or larger plane blades.
The second question would be on sharpening more complicated edges like a bowl gouge with really swept back wings. How hard is it to keep a continuous bevel. It's really easy with a jig like the Wolverine and once you get skilled not too hard free handing on a regular grinder. I couldn't tell in the video if you had enough clearance to really swing the tool.
I've been interested in these for sharpening carving tools because I have so many different profiles. It's just kind of expensive when you get into buying several different plates and the slotted sandpaper probably only comes from them I assume.
Re: another sharpening video
robo hippy
I had pretty much the same questions. They do have a set up so you can use your tormek jigs on them. Seems like a good idea.
I do consider that there are two types of sharpening systems. The basic grinder which is pretty specialized for turning tools, and systems like this one or the Tormek, which are more suited to the finer edges of carving tools, bench chisels, and plane irons.
One can never have too many toys.
robo hippy
Re: I have a couple of questions
mjonesrdg
It looks like it would be sweet for sharpening skews. Gouges would no longer have a concave bevel, which might have both some advantages and some disadvantages. The demonstrator speaks of the importance of lapping the back of the chisel....wonder how many turners make an effort to lap the back of the cutting edge of their gouges?
eliotandmax
I've been making my own sharpening jigs by simply attaching sandpaper or emery to a mdf disk and making a kind of "scary sharp" system that works on a lathe -- especially good on a variable speed lathe. For honing, I just put that green honing compound right on the mdf.
I much prefer the Wolverine for turning tools. though. I use these home made ones only to flatten and hone the bottom, long, flat part of a bench chisel. I got tired of doing it on sharpening stones.
Carol Reed
True, true, Reed.
I have several sharpening 'systems.' Wolverine for most turning tools. Just used the Worksharp for bench chisels and plane irons. Love it for that. Next up is my skew. And the big spindle rougher. I have difficulty with them on the Wolverine and totally free hand for me is way too unpredictable.
