Drill presses
robo hippy
How come drill presses don't come with variable speed motors????
robo hippy
Drill presses
robo hippy
robo hippy
Mine does
steven antonucci
if you move the belt... just like my lathe!
S
this one does-I've been drooling over it *LINK*
http://www.powermatic.com/Products.aspx?Part=1792800
And another one *LINK*
http://www.lagunatools.com/drills/drill-platinum17v
and a Delta *LINK*
http://www.labsafety.com/delta-12-variable-speed-drill-press_s_98756/
Delta, Powermatic
both have variable speeds. I'm sure there are others.
I want this one *LINK*
http://www.sears.com/shc/s/p_10153_12605_SP101A12475S5858014801P?i_cntr=1326317526206
Re: Drill presses
Mike Stafford
Having the capability to dial in a speed on my drill press is one of the reasons I still have a Shopsmith in my shop. I use it as a drill press and horizontal boring machine primarily but occasionally I will also use it as a drum sander and disc sander.
In my opinion it excels in those functions for the work that I do. I already had the Shopsmith so I saw no need to buy those other machines. An oscillating drum sander would be nice on occasion but not at the expense of the space it would require which I don't have.....
Starting to blur the line...
Scott in Falcon
between drill press and mill, aren't you John?
Re: Drill presses
Dennis in Southern Oregon
I don't recall ever seeing a drill press with a variable speed motor. Most have a constant speed motor and a Reeves drive or equivalent to give a variable spindle speed. The Reeves drive gives increased torque as the speed is reduced, whereas most variable speed motors do not.
Dennis
Re: Drill presses
Brian McInturff
Mike hit the nail on the head. The shopsmith though not a good saw is an exceptional drill press. Once you use one as a drill press you will understand.
Re: Drill presses
bill Crommett
My Shopsmith is mostly a dedicated disc sander, but I occasionally use it for a spindle lathe when I need to make a 4 or 5 foot spindle. It is too heavy for me to stand upright any more, so I bought a big Delta floor stand drill press.
Did y'all happen to notice the price .....
JamieDonaldson
..on this Craftsman-$10,616!!!!???? I have seen some emails recently about Sears pricing errors, and I ASSUME this is another of those errors!!!
Re: Drill presses
robo hippy
It would be nice to have one with a 3 phase motor, maybe 1 hp, and speed controls like my lathe. Just so much better. Maybe a deeper throat as well. Just makes sense. Manufacturers are you listening? Hey Brent English, maybe that is another tool you should make. I'll place an order now.
robo hippy
not 3 phase but.... *LINK*
http://www.baileighindustrial.com/drill-presses/dp1500vs.php
This is right around the corner from me *LINK*
I don't have the space to put it in even if I did have the money.
http://www.golsn.com/listings/equipment-tools/industrial_machines/2474958.html
Re: not 3 phase but....
robo hippy
Seems like choices are heavy duty industrial, or wimpy 'craft' type that I would destroy in a month or two.
Might have to make my own.
robo hippy
Reed I've looked at that option. However I also need a beefier machine and I'm not sure just adding more horse power to the one I have is a good idea. However if I find a 1 horse 3 phase motor cheap I may consider it. VFD's type phase converters have come down to less than $300. As you see above good quality beefy drill presses are expensive.
I have used the new Powermatic and it's pretty sweet. I didn't use anything large in it so I don't know about the power handling capabilities. The only thing I didn't like was the Keyless chuck. It takes 2 hands to loosen it and then the drill bit drops through the table to the floor. You need 3 hands. I love my keyless chuck used horizontally in my lathe but not in a drill press.
Dick Strauss
Robo,
Buy an old PM1150 or 1200 three phase machine and add a VFD for $100-150. Then you would have a true EVS machine with 6" of quill travel (you'd also have different torques ranges via belt settings).
Re: Drill presses
Keith Tompkins
Hey Reed, I have two drill presses: A Rockwell radial drill press I bought the year I got out of high school. It's a home version of the famous Walker-Turner radial drill press. Here's a pic of my other drill press: Model 944, serial number 1- 944. It's in nearly new condition made in 1939 as far as I can tell....WT serial numbers are hard to interpret, but it may be the first unit produced. In any case, a very rare pre-WW2 unit. It has the original motor, flexible light, table elevation crank, and ultra-rare belt guard. It has 4 speeds, but can be fitted to 16. I bought it at auction from the estate of a well-known sculptor years ago.
Bob Raasch
I have the Powermatic PM2800, 18", purchased November 2010 from a local dealer. The quill and keyless chuck have significant runout. The quill at about .005 -.010 or more. I don't know about the chuck, but placing a center finder in the chuck, at 400rpm, one can easily see it's runout. Also I can grab the chuck and easily move it laterally on it's shaft. The chuck is not loose, however. The quill appears to flex, especilly when used at full depth with the side depth stop. The thing vibrates excessively at aroudn 400 rpm. Have used parafin wax on the forward belt, with positive results thus far.
I never had any of these problems with my 35 year old no name knockoff drill press that I purchased new for about $200. So far, this machine is a huge disapointment. Curious if anyone else is experiencing these problems. Appreciate any advice.
Don Evans
Hey John:
First off, I would not have a keyless chuck on either of my drill press either.
A cheap way that may help the bit falling problem, as opposed to buying a new chuck, is to that a bike tire inner tube, cut a 1/2" wide strip of rubber several inches long (you have to determine length). At one end punch a hole (paper punch size?). The other end of it will be attached to the press some where but you want to be able to get other end and pull hole larger and slip it over bottom of bit and up to shank. If you get it right with the length the bit will pull slightly sideways when turning the chuck and not even fall out but if it does the strip will hold it from falling. Put another hole a bit further up the rubber and make it small enough for the smaller bits you may use.
Also, one of these more powerful magnets on the quill may hold most of the bits used except for larger Forstner's.
Don
Re: Drill presses
Galen Vetterick
Keith, I can send you a can of machinery gray or a pair of sunglasses.
Re: Drill presses
Keith Tompkins
Hey Galen, The early WT machines weren't gray, they were a greenish color. This drill press was painted tan with a paintbrush when I got it.. I repainted it as close as I could to original without going to custom blended paint. I should have adjusted my white balance, it's not as bright as it looks
