Does anyone know what the standard threads are for a beer tap? I want to turn a tap handle for my nephew and want it to thread on easily. I don't go to bars much. Might have to just visit one and take my pitch gauge and do some measurements. Any ideas for a metal thread insert source?
There's a pretty story in the Oct. 2011 American Woodturner about Mark Supik in Baltimore who has a company which makes beer taps. There might be something in that article which would help. Their website is marksupikco.com which has a lot of information on tap handles and contact information.
Did one for a friend's bar. Instead of tapping the wood, I drilled the blank with a 3/4" hole before turning the handle to take a 3/8x16 coupling nut which was then set into the handle with epoxy when finished. Fine adjustment of the handle's orientation (family coat of arms) was done with a couple of thin brass shim washers.
The ferrule is a section of a chrome sink tail piece.
Several other friends have asked for one. They're fun to do, and a reliable source of free beer.
Don -- the advise above is good, but the construciton may depend on the customers specs.
I did a run of commemorative tap handles for Alaskan Brewing this fall and they wanted a stainless steel shank into the handle. I drilled and epoxied 3/8 by 16 stainless steel all thread rod about 11 inches into the handle leaving a stub for commercial threaded fittings at the bottom -- which mounted to the 3/8 by 16 threads on the top of the taps.
These appear to be the kind that are inserted by threading them onto a bolt with a stop-nut, then removing the nut and bolt -- is that correct?
I made some tap handles for a soda fountain a few months ago, and the inserts supplied by the tap manufacturer were the kind with a slot on one end for insertion with a big standard screwdriver. These were not acceptable, tended to break (needed larger hole???), and were difficult to insert nice and straight. I ended up turning solid wood pieces with no brass adapter, and used a thread cutter to thread the wood (pretty hard species), and reinforce the threads with CA. I think the inserts at the link above look better than what I tried.
