Windsor stool
GolfSteve in Calgary
Following up on my question before Christmas about "is there a comfortable chair to play a guitar on", I built this three legged stool. It was also practice before starting on a set of Windsor chairs, as I am not a very good turner.
The design is based on the Dunbar shop stool article in Popular Woodworking (#178 Oct 2009), but I converted the stool from a four legged stool to a three legged stool.
The seat is poplar (14" diameter). The beads on the OD of the seat were the most frightening turning task for me. The legs were sawn from kiln dried 3-1/2" square quartersawn maple baseball bat blanks, and are about 1-3/8" max. diameter. The legs tenons are tapered and wedged into the seat mortises.
The finish is milk paint - the legs are red over black over red. The seat is blue over yellow over red over black. There are three/four coats of colour because I decided I didn't like the original two colour red/black scheme. Two coats of polymerized tung oil are applied over the milk paint.
There are two things that I liked about this project:-
1. Windsor chairmaking is liberating in that you can screw almost everything up and still get a good looking project. Every leg is a different size and all the holes are drilled at the wrong angle, but it all came together. The important part is getting tight fitting joinery.
2. Milk paint is liberating because you can paint it like your 14 year old son would if you forced him to paint the chair during the summer holiday "because you're part of this family", when all he wants to do is play Nintendo and sleep, and it looks perfect.
On the downsides:
1. Next time I'll turn the tenons oversize, then let the parts dry for a few days before turning the tenons to final dimension.
2. A three legged stool can be unstable if loaded along the periphery of the seat near the mid-point of a stretcher. I have a two year old daughter who loves to climb and I think she could tip this stool over easily when climbing onto it. Perhaps I should have given the legs more splay.
3. When reaming a tapered mortise freehand, it is hard to get the angle exactly the same as the pilot hole.
4. Reaming a round hole is difficult. A slightly dull reamer seemed to make the job a bit easier.
