Wood with dark hardwood
Starry S Chan
I got some Pistache logs last week. This wood has cream color sap wood and a dark color hardwood. I turned two regular half log bowls today and I did not like the look of the bowls. Both of the them has two dark color hardwood patches at the rim.
The bark of this wood is not tight and clean. This is a lawn/sidewalk tree so the bark has moss on it. I am going to turn two NE bowls tomorrow to see whether they look better.
How would you handle wood like this? How do you deal with the loose bark? Do you break them off and how do you clean the bark?
Starry
Re: Wood with dark hardwood
Ric Taylor
Ric Taylor
Starry,
I don't see any connection between moss and sidewalks or lawns. However, I would think that moss would add interesting character to the bark.
When dealing with bark, CA glue is your friend.
Ric
Starry S Chan
I mean heartwood and not hardwood.
Skip Beardsley
You might want to think of pressure washing the logs. Sometimes I do this if the logs have been rolling around in the dirty to remove any dirt or stones which get caught in the bark.
If you don't have a pressure washer try the local car wash if they have the bays with a hand wand
Skip
john Veerkamp
I also like moss on the bark. I seal with spray shellac and it holds the moss on fairly well. If the bark is loose in just a few spots, spray with the shellac and then use CA glue. If the whole bark edge is loose I gently pry the bark off and leave the natural edge under the bark as the finished edge.
