Turned dowel into a spline shaft.
Lloyd James
I turned a shaft 1- 3/8 Dia., and I want to cut 12 splines along the length..
I made a fixture for making grooves with a trim router. The fixture sits and is center on
the lathe bed.
I am using a small Dunlop/Sears lathe that has 60 index holes in the belt pulley. There is a pointed pin that slides slides forward to lock the chuck.
I am having trouble with this set up. Sometimes the pin just slips out of the hole.
I have tried putting a clamp on the pin and part of the rear housing. This method
Has worked, but is kind of crude.
Has anyone ever made an index plate to go with their lathe?
Do larger wood lathes have a way to index at different degrees of rotation?
I want to make toy tires for a skid loader design of mine. I want to make the tires
With treads to look like they are earth moving tires.
I will slice the spline shaft like you slice a tomato, and then glue to halves together
with the grooves of each half staggered to give a rough look.
Thanks for any suggestions.
Re: Turned dowel into a spline shaft.
Re: Turned dowel into a spline shaft. *LINK*
I find the Ironfire index wheels to be great. I have one and have put many hours on it. You do have to build some sort of way to hold the index pin but it's not hard and they give you some rough instructions. I don't now if they make one for your lathe but you can check them out. I just started working on a 16 sided fluted pot for a friend and used the index wheel for part of it.
http://www.ironfirellc.com/
Indexing wheel for Powermatic *LINK*
Doc Green
Here is a link to a description of my setup for a PM 3520B.
Click on the photos to enlarge. Click outside the photo to return to the text.
Good Luck, ~Doc
Doc's Indexing Wheel
Here's mine for 3520A powermatic
I simply drilled a couple of holes and tapped them. Screwed a wooden block to the lathe that had holes drilled to match the index wheel. If you want to go all out Alisam indexing plates look really great.
Thanks for your threads
lloyd james
I want to thank all you guys for giving some good directions to go. I had trouble
finding the links that you presented. Thanks again. I better think about getting
a larger lathe, so I don't have to buy 2 of these index discs. :)
I will submit some pics later of my wooden off the road tires.
