A different take on Segmented Turning
charlie belden
When you thing of Segmented Turning, usualy Round & Brown With a Pattern comes to mind. Malcom Tibbett took segmented turning in a different direction with his Mobius Strips pieces - and their incredible offsprings. Springett hs taken it in a different direction with this Streptohedrons and moved out into spirals.
Here's a Ram's Horn done in SketchUp that starts with three rings with the same square cross section but in three graduated diameters. Quarter each ring and combine them and you can end up with this.
Here's how it can be done, using Paper Joints to make Quarter Rings.
As long as the cross sections are the same they can be joined, in any angle, in this Square Cross Section version they can only be joined in 90 degree increments. If the cross section were round, they could be joined at any angle.
Here's another example of this different form of segmented turning done with square cross section "rings".
Lot's of possibilities here for anyone who wants to try something that isn't symetric about a single axis but isn't ready for the challenges of multi-axes turning, even with Barbara Dill's wonderful help ; )
Re: A different take on Segmented Turning
One little technical question Charlie,
JamieDonaldson
... how do you mount the square ring blank for turning once the center is cut away? :O
Steven Antonucci
The difference between theory and reality
steven antonucci
if you haven't heard the joke, I'm sure Google will explain it :D
I have no doubt that you could prototype something similar very quickly on the lathe. Why not give it a shot to see if it can be done? Sketch-up is good for theory, but let's see it in wood?
Steve
Steven Antonucci
Start with a hole
steven antonucci
Turn a disk.
Bore most of the way through it.
Reverse in chuck in the hole you just bored.
Finish boring the hole through.
Turn a jam chuck.
Put the donut over the jam chuck.
Turn the first two faces.
Reverse
Turn the last two faces.
You probably spend more time making fixtures than you do turning, but this would be very simple to turn.
Steve
The difference between "turning" & "machining"
charlie belden
This branch of "segmented turning" is more "machinist" than "turner" and does not lend itself to the Wiingiin' It approach that most turners do (except perhaps sprindle turners who seldom do One Of A Kind turning). It does require scaled drawings, scaled paper patterns to get the required angles right and, as is the case with turning bracelets, jam chucks turned for a specific size and application. But considering what segmented turners go through when designing a segmented piece, cutting all the parts and then gluing everything up - parts for these things are a bit simpler.
To be clear, this Rings With Identical Cross Sections idea is not something I thought up. I started playing with Springett's ideas in order to try and understand them, rather than just admire them and wonder HOW they were done. As I become more familiar with SketchUp and build virtual models of things I see and only THINK I understand, I gain knowledge and an understanding, which may or may not be applied. In the process, my POSSIBILITIES inventory goes up. With more knowledge of possibilities, there may be more serendipitous synthesis/ combinations - and New To Me pieces often are the result.
If any of these images cause a light bulb to go off in another turners head . . . I think that might make Mr. Springett happy as well. There's a LOT more in his book and for me, the $27.95 price tag for admission to this area of turning is a good buy.
Keith Tompkins
Re: The difference between "turning" & "machining"
Keith Tompkins
Charlie, I've been combining segmented turning and multiaxis turning for several years now....I haven't done too many lately, but more are coming ;)
Jerry Bennet does a lot of things like that. I tried to find a website of his work and failed miserably. It's incredible stuff.
Dang Charlie, you keep coming up with interesting
Keith Newton
stuff. I need to send you some pics of my current project. It is a reciprocal grid pattern loft floor, using sliding dovetail joints, that will have a tempered glass walking surface, which will allow you to look up or down through the floor.
I have been through yet another faulty hard-drive crash. I don't think the computer gods like me.
The two turnings that I mailed to you came back, so I must have gotten your address.
These are based on a David Springett's book
charlie belden
I just did the SketchUp 3D models so I could better understand some of the concepts in his book. I thought he only did those Chinese Balls (balls inside of balls - sometimes with spikes!) . Boy was I wrong. I come up with some Wild Hare ideas - but nothing like this stuff.
And when it comes to interesting ideas, your Arborescent Desk ranks up there with Esherick's Corner Desk (the one with all the odd angles). You, on the other hand, not only came up with the idea for your desk, but actually made it as well - includng the hinges for the "the swing up front".
I've tried to do a SketchUp model of Esherick's Corner Desk - but with only a few photos of the piece didn't have enough info to do it. Haven't even TRIED to model your desk - or any of your interesting pieces of furniture. Just how you worked out the hinge mechanism let alone how you MADE them baffles me.
Charlie, I'm wishing I had some time to play with
Keith Newton
this. It seems to me that I could make parts a lot faster with close enough tolerances by sawing then sanding to the mark on my edge sander.
A couple of things that I would try, would be going to ellipses, rather than arcs of a circle. Also, mounting the parts on a sled type fixture, which held them up at a certain angle relative to the band-saw table, should allow achieving a helix.
