grinder dust collection
Don Evans
After seeing J. Lucas setup with his grinder I said I would post pix of mine with an old Delta dust collector. This setup really sucks, if you know what I mean. The outlet from the blower is piped outside but you cannot see that in the pix.
I have not posted pix in long time, so we'll both see if the works together.
Don
Re: grinder dust collection
SWEET
Outside to what?
Ray Carson - Lawrenceville, NJ
I didn't see John Lucas' setup.
Thanks,
Ray
Re: Outside to what?
Don Evans
Ray:
The pipe in background of the pix is 6" which goes up the inside wall then 90 deg, then through the wall. On the outside I installed a non-standard cloths dryer vent. This particular vent is one that turns up and has a cup inside it that sits down on the pipe. Outside of that pipe is cover that is 8" diameter and it does 2 things. 1. it traps the cup (which is upside down) the cups job is to seal the pipe that collector is blowing out through. 2. keeps wasp etc from getting into the pipe when it is turned off (cup falls back down over pipe).
I would not do it this way again, in fact when I get better weather back I may modify it. The problem with it is it is only 4" diameter inside pipe which is cutting down on efficiency.
Another thing I learned is I spent 2 years trying to figure out what the brown stain was on the siding of the shop. Looks like cherry dust in the crevices of the vinyl textured siding. It finally hit me that it was metal dust from sharping turning tools which has rusted. But the good news is it gave me a really good image of what would have been in the shop, instead it is outside.
This dryer vent I'm talking about points the air flow downward through the outside 8" pipe.
I'll modify it when I can to take it at least a couple of feet from buildings side and use a 45 deg pointing downward, cover it with screen wire which will act as a wasp deflector and also spark arrestor but sparks are not a concern really.
The hot metal is going through the steel impeller, then through 10 feet of metal pipe turning 90 deg all while being cooled by the air flow then through the vent. But it does prove that their is a very fine dust when sharping and thats all this grinder does.
Any heavy grinding is done outside, I have a cart with vise and another grinder on it that I wheel outside of the shop, it's also set up for torch work etc. When I build the shop, I included a 6 ft. covered porch with a knee wall made of cement blocks so it would trap torch sparks etc for any metal work. Since then I've realized I didn't need it that big, it was 35 ft long so I enclosed half of it and moved the cyclone collector and wood dryer into that room and storage.
Don
Just getting back to seeing this. Sounds like a neat setup. At first I thought it was going into a woodworking collector or something. But then I realized how silly that would be.
