Non-turning, but still woodworking
Steven Antonucci
steven antonucci
My MIL bought herself some tiles with her house number on them back from Italy. My wife volunteered me to make a small wooden plaque to mount them on. The goal it to hang them outside her front door.
I used white oak to get the best locally available long life wood for outdoor use here in NJ. My question is what adhesive should I use to attach the tile to the wood, and what finish should I use on the oak to prevent it from drying and cracking in the sun? (The wood is dry, but the area is going to expose it to the elements)
Thanks
Steve
P.S. If the tiles fall out and crack, I am a dead man...
Re: Non-turning, but still woodworking
Rich Pearson in Mill Creek, WA
In addition to gluing them to the backing, would the tiles be suitable to using a dadoed frame around the whole thing?
If you could slide them into a dado (top and bottom) they would not need gluing and they wouldn't fall out.
Carol Reed
Rabbet the inside back of the frame and install the tile behind the rabbet. I'd even screw on a backer plate to 'trap' the tile. I'd call it CYA. :)
Or preplan a funeral. :D
silicone
Stuart Johnson
A good spar varnish will look good and should hold up to the elements. I think any finish will need to be renewed from time to time.
Clear silicone caulking is one of the best adhesives for this. It stays flexible and holds really well. I use spar varnish for things that are going to be in the sun although if it's in the weather very much you will have to rejuvinate it about every other year or so. I made my last outdoor project out of mahagony and didn't finish it at all. I just let it go barnwood gray.
mjonesrdg
First, I would select cedar or redwood for the numerals. Use Penofin clear penetrating oil or Daly's Sea-Fin Teak oil. Coat them front and back with enough coats that they just begin to shine. Why? because it is not a film like vanish that would need sanding or stripping when the oak begins to weather. Just wipe on and touch up every other year or so to keep them brand new.
matt overton
Clear silicone was used to support 20 large pieces of granite on my outdoor kitchen on my deck with great success exposed to the elements. I agree a non film like penofin would work well, but still need occasional maintenance.
What Dick said!
