RIKON Model 70-450 20 x 37 Woodfast Lathe EVS
Re: RIKON Model 70-450 20 x 37 Woodfast Lathe EVS
Woodfasts were excellent lathes, back .....
JamieDonaldson
.. in the years before they were sold to Rikon. I still use my 409 frequently, but have not used the Rikon version, so can't say if the high quality is still the same.
Rob Wallace
Rob Wallace
I would hope that the holes in the tool rest supports ("banjoes") are a standard size ( e.g. 1"/25mm) for the tool rest shanks - couldn't find this information in the description or in the "manual" - it's a pretty "lightweight" manual overall, typical of other Chinese imports. You want to make sure you can get aftermarket accessories that fit directly without modification.
You may want to look closely at how the headstock swivel is controlled and adjusted - potentially a weak spot in the lathe design. I personally don't like swivel head lathes, but SLIDING head lathes are great! If you need to get to 20" swing this lathe might be OK, but I would suggest the Powermatic 3520B instead.
I certainly hope the control box ("switch") can be moved from where it appears in the photos - for me, having it in this place on the lathe would REALLY be in the way for any kind of turning, and it will undoubtedly get very dirty very fast sitting where it is - right in the line of fire! (....whoever the marketing photo advisor was for this obviously had no clue about how a lathe works!) There is no mention of even how or where to mount the "switch" in the manual as far as I could tell - it appears there are only two places on the ways to mount this box - both "in the way" for me. There is no mention whether this control box has a magnetic face to move the on-off and speed adjustment controls to a more desirable place. Pretty poor manual, actually.
I don't see any real advantages of this lathe over others of the same general size class. Don't rule out the Jet 1642 for about the same price - no swivel head, and a proven positive record of several years.
I would finally suggest being careful with those "explosion diagrams"!! :D
The above, my humble opinion of seeing this machine only on-line and not in person.
Rob
Steven Antonucci
Rikon Bandsaw is good, don't know the lathe.
Re: Rikon Bandsaw is good, don't know the lathe.
walta
The Powermatic 3520 has the same swing and bed length but weighs 630 pounds verses 461.
Do you think it is interesting that price of both lathes are within 2 cense a pound of each other.
Walta
I own that one, sort of
Ken DeMarco
Ok, not sure what happened to my first post, but I'll try again. I bought a 70-500 last March, and have had quite a few problems with it, to the point that Rikon sent me a 70-450 loaner while they worked out manufacture issues with the 70-500
I Have been using the 70-450 for about six months and have a lot of good things to say about it, very smooth, no vibration plenty of power, love the swivel headstock. Rod at Rikon has been great to work with in resovong issues. The lenght of time it has taken to come to a resoulution is NOT Rod at Rikons fault, but mine, as some big life events have gotten in the way of turning time.
Having said all that, the 70-450 is not without issue, and I'm not 100% sure part of the problem is not me. it seems that it does not turn quite true, I am totally unable to reverse a bowl, after cutting the outside between centers, to do the inside without going quite a bit off center, never really had this problem with other lathes. also seems to turn just bit oval, as in if i turn something and then mark it with a pencil as it turns it doesnt mark all the way around, but on two opposite sides. But like I said , this may be partially me. I have just today sent a message to Rod at Rikon to see if they have fixed their manufacturing problems, if they have I think this is probably, by far, the absoulute best value in large lathes (especially after Powermatics 33% price increade last year!
Any other questions, let me know. I'd be happy to answer
Ken DeMarco
Re:  I own that one, sort of
Ken DeMarco
To answer some of Rob's Questions
1: all my 1" tool rests fit fine
2: The headstock swivels smoothly, and has an alignment pin with stops at 0 45 and 90 degrees, locks positivly and seems to line up accuratly
3: The control box has two places to mount it and can also be places on the bed ways, for me, I have never had it so that it is in the way.
4: yes the powermatic might ne a better lathe, but is 1500 more, I think this lathe is far better than a 16" jet with better support.
Hopefully I will have more info soon
Ken DeMArco
Dave Peebles Lyons, Ohio
Hi Ken,
When I first read this from Bart, I thought of you.
You guys should email each other. :)
You are the man on this lathe.
Hope all is well buddy,
Dave
