My last video for a while- Hunter Hercules *LINK*
I had sound problems with this one because I had to wear my face shield. It pushes the mike to close to my mouth and also echos the breathing more. Anyway Hope you find it useful. The Hunter Hercules is a very interesting tool. It would be especially good for beginners and yet it leads to more advanced techniques such as bevel rubbing like using a bowl gouge.
http://www.youtube.com/watch?v=vzrLN8SQ8ms
Re: My last video for a while- Hunter Hercules *LINK*
Mike Stafford
Mike Stafford
Excellent John!
There is one more cut that you can make with the Herc. Terry Scott showed Mike and I this use when we were in Norway.
You turn the tool upside down while holding the tool nearly vertical and sheer scrape with the trailing edge. You can get an amazingly smooth finish in this manner.
Another good video!
jake Niedling
John - Nice series of video's. It's like being right there in your shop. Great for the beginner and nice reminder for the experienced turner. Hope to see you at Crossville club or at TAW this month.
Leave it to Terry to figure out something else. I'll give it a try next time I can get in the shop.
I plan to be at both. We'll have to have dinner or something at the symposium.
Jesper, Denmark
Jesper, Denmark
The sound quality is perfectly ok, John.
Don Leydens
Don Leydens
John, thanks for showing the versatility of these tools. I keep finding new uses for them all the time. Beautifully clean cuts with minimal effort. I like it! You're right about the Mini Herc, too. There are so many smaller turnings that can benefit from this. I've found them a joy to use and your video shows some of the techniques very well. Thanks for posting.
Mike Foster
John, you have really been busy. Great video of an interesting tool. I love my Hunters, but have not tried this one. May have to get one some day.
Stuart Johnson
Another fine video and it finally clicked with me about what you mean about flipping the video.
One question, when cutting on the inside of the bowl it looks like you are cutting above center. Are you or does that appear because of the camera angle? I thought the Hercules was always used dead center.
With that tool I am cutting above center. It's not necessary I am trying to work around a tripod and camera and it somewhat limits where my body can be. Don't get below center of course, on center or how far above center is a relationship between the angle of the cutting edge, the tool rest height, and where and how you hold the handle.
When cutting the inside of a bowl with bowl gouge or Hunter tool I often start at the lip about center or slightly above. Then the tool seems to go in an arc getting higher and then slowly coming back down to the dead center for the last 1/4". I think it's because I tend to use a straight tool rest a lot. The tool rest is close to the wood at the lip and center but further away as you run down the bowl. This changes where and how you hold the tool and I think that's why I end up with a sort of arcing path with that type of cut.
I have curved tool rests but for bowls this size I don't pull them out because the tool never gets very far over the tool rest.
Dale Cook
Very nice video John, That tool looks great. One question, is it better to use a square tool like your using with this cutter or would a round one work as well, I like the round ones just because I can roll the edge of the cutter the way I want especially when hollowing.
I wondered about this when I first started playing with the Hercules. I have a square cutter tool similar to the Easywoodtools. For roughing out the shape I don't see much difference. The square tool is a little easier to fine tune the outside of the vessel although it's still a scraper and it's too easy to push just a little too much and take off wood where you don't want to. The Hercules is the same when used flat.
With either tool you can shear scrape which helps clean up tool marks or slight bumps or dips that are hard to avoid when scraping flat.
The Hercules has the advantage that you only need one tool to do the inside and outside as well as shear cutting and shear scraping. Of course no turner ever (and mean ever) buys only one tool. :) To paraphrase the famous mounaineer when asked why he climbs, Because it's there. That's why we buy one more tool, because it's there.
Galen Vetterick
Thanks John for another great learning tool. There is nothing wrong with the sound as far as I am concerned. For the life of me though I don't understand the turning videos done to music! Guess they are for entertainment and not learning.
Mike Stafford
I agree with Galen....
Mike Stafford
skip the music and please don't sing John! :b :D
you haven't hear me sing..
It might be a good thing. :)
Well Done John!
Don Orr
I finally got a chance to watch your recent videos. I really like them a lot-very nicely done. Excellent point-of-view camera angles and nice and close to show what is happening at the cutting edge. Your voice is also pleasant and easy to listen to. It makes a difference. Your skill is obvious and your knowledge is extensive. Thanks for putting these together for us.
