I've been playing with TransTint........
JamieDonaldson
...dyes, and managed to make some KY Koa out of fiddleback maple. The first dye was a light wash of black, sanded back slightly, then a top wash of brown with a bit of yellow. It made a very close match to a piece of Koa I was using as a sample, and is 16" square in my regular form.
Re: I've been playing with TransTint........
Wow, this first uploaded image really .......
JamieDonaldson
... popped the saturation, as it's not nearly this intense in real life? The second image is more accurate, and I've not noticed WC software doing this in the past? :\
Nice Jamie. I bought some Trans tint but haven't had the time to use them. Well that's a lie. I did use them once on a customers clock replacement part but that's it so far.
jake Niedling
Nice piece and the dye really changed its look. Is the dye water or alcohol based? Did you have any raised grain to deal with? What did you sand with between dyes? Appreciate if you could share any of your learnings.
Jake- I mix TransTints with regular....
JamieDonaldson
...rubbing alcohol to avoid raising the grain, and have used the dye also with H2O which did require sanding to cut the grain down. I hand sanded back the black with a 320 pad.
Mike Foster
Very nice Jamie. I don't have any Koa to compare it to, but it looks nice from here. Love your square bowls. Interesting that you started with black as it doesn't really show. Must have just darkened the tiger. So now I guess I'll have to find some trans tints. Are they considered archival quality?
Don Leydens
Don Leydens
That is one beautifully made piece, Jamie! SO well done. The colors sure made the grain pop, too. Good job!
Mike- yes, they are the new metallic ....
JamieDonaldson
...acid dyes and are judged to be very stable and lightfast. Some of the colors are not as intense as other dyes, but by mixing applications of pure pigments such as acrylics and drawing inks in layers, I can achieve just about any effect that could be done with older and less stable anilines dyes. I don't believe we played with these dyes during our class with Gary at the Folk School?
