Another one for Steve
Mike Foster
Latest diatom. I saw the diatom and immediately envisaged how I could possible turn it, so was hooked. It was a bit more complicated to complete than other pieces that I could turn like a box. Rather than turn tenons on it I cut a blank where the join would be and glued it back together with a paper joint. I then turned the shape (described below) using 6 different mountings. I separated the piece, and turned the shapes on top and bottom and got everything as near to 1/8" as I could. I had to hollow the points with carving tools to get them to the same thickness. Once hollowed, the piece was re-glued and then pierced and carved. I love how doing these things really pushes my limits in figuring out how to go about them.
The last two photos show how I mounted the piece to turn the outside. Now I could have done this much easier by using a bandsaw to shape it, but what fun is that? It was a little daunting to turn those inside curves. Not at all like turning a multiaxis spindle. Here you have the whole blank spinning around and coming to meet the tool. Requires total attention and concentration even using a boring bar setup. It would be real easy to get the cutter too deep in the air space and have that blank wham it next trip around.
Re: Another one for Steve
Mike I really love these Pieces. They are so cool. Technically of course they are fantastic.
Steven Antonucci
Only 5 sides?
steven antonucci
Looks a lot of fun until someone loses an eye.
My first turning of the year came off the lathe in one piece, but I pierced it with a torch by accident (all 360 degrees of the goblet, and at way more than 360 degrees F.)
I just might have to try something like this, small scale of course. I only have 16" to play with...
S
Brad Vietje
Beautiful, Mike!
Brad Vietje
... but I think we'd all forgive you if you cut the outer profile on a bandsaw ! The end result is really nice -- hope to see it in person one day.
Safe spinning & Happy New Year,
Brad Vietje
Newbury, VT
Mike Foster
Thanks guys. I was trying for a more subtle color, and started with some aniline dyes, but the result was just too splotchy, so I had to even it out with some airbrushed acrylic, which helped but intensified the colors more than I wanted. guess I could have sanded it back and tried again, not.
I like the bold colors. You see bright colors like that on a lot of sea creatures and I believe this piece mimics some of them.
