Hackberry saga
Carole Valentine
Haven't posted any pics in a long time so I thought I would post a pic of this piece of Hackberry. When I got it about 2 years ago in log form, I thought "Hackberry...usually soft and featureless, but has this a little figure and some spalting". Then the saga began. Should have suspected some problems when I saw sparks from the chainsaw! I discovered when I was shaping it that this was the hardest piece of wood I had ever turned. It was not soft anywhere and what I had thought was spalting was not, unless it was petrified...it was like steel! But realizing that I had a very unusual piece of Hackberry, I decided to core it and at least get two bowls. The wood had other ideas. After 4 trips out of the chuck (should have used a faceplate) and across the shop, it won. Ok, so I will just do one bowl. Sharpen and hone my favorite Thompson gouge..."Darn this stuff is hard...my gouge is just bouncing off it in places and I am sharpening every few minutes!" Anyway, this went on through 3 re-turnings...the latest which was yesterday. I finally got rid of the little humps using my Multi-Axis scraper set on shear plus a little negative rake with an aggressive burr then a fine burr for the finish cut. The "Hackberry from Hell" is done. Don't know that I want any more of it.
