Face plates
Face plates
Face plates
mark j. thill
I'm in the market for a larger face plate. Is there any difference in aluminum - steel - cast iron or stainless steel, or are they all about the same ?
Re: Face plates
Re: Face plates
Carole Valentine
Don't know what kind of chuck you have but I use the dovetail faceplate rings almost exclusively now. I have the SN2. I have some aluminum faceplates but do not like them...always feel like the larger ones are flexing just a hair, though it is probably my imagination. I also don't like the soft aluminum threads on the hardened steel spindle threads. They can lock up.
Re: Face plates
Steven Antonucci
Huge difference between aluminum and steel
steven antonucci
If you can afford the steel ones, buy them. The only advantage to aluminum is price. Oneway faceplates are exceptional.
Steve
Re: Face plates
Re: Face plates
Bernie Weishapl
I use the steel face plates. Had trouble with the threads that screwed onto the lathe. So quit using them.
Re: Face plates
Bronze or stainless steel
Bob Hackett
Iron or steel faceplates will stain any wood with high tannin content (like Oak and Chestnut) that you turn green.
Rust is always an issue with green wood regardless of species.
The only steel or cast iron faceplates I use anymore are the ones I had powdercoated. They still rust where I`ve chipped the coating but I beat the staining issues by using a dry block between the faceplate and the blank.
