My go to WeCheer for sanding/carving has finally gone belly up. The armiture that contacts the brushes has worn down to the point that the brushes do not make a complete contact thus throwing sparks like a sparkler, well at least it did. I have e-mailed WeCheer in Tiawan. Good luck on that one. I want to find out if I can buy a new armiture/cost. Has anyone had the same problem and what was your solution......buy a new one? Thanks
Hey Dick, I believe your problem is that the brushes have worn out and the metal parts of the brush holder, or whatever, are coming in contact with the armature commutator. It's the metal to metal contact that causes the excessive sparking.
Perhaps a new set of brushes is all you need, provided you didn't run it very long after the sparking began and damage the commutator.
Hi Doc, The comutator you mention is worn away where the brushes make contact. I just bought new WeCheer brushes. Yes, the old brushes were gone. In fact, one of the springs is about half as long as the other ( I have no idea where that went unless it was ground up into powder). As I remember, the last brushes I bought sparked from day one and sparked thereafter.
As others have mentioned maybe it is time for a new tool. Dang I hate spending money so close after the X-mas dent
PS - Happy New Year to you and yours. See ya Monday night.
When the commutator starts wearing or getting glazed, you can dress them with a Tommy stick, I think it is called, which is an ablative little stick which breaks down when you touch the spinning commutator somewhere between the brushes. The grit spinns around cleaning the copper, and seating the brushes.
After things really get bad though, you can true up the commutator by mounting it on a lathe, and dressing it with a cutting tip. I have even bonded a loose segment back in with epoxy and soldered a broken wire to bring them back, but nowadays it is sometimes heaped to just toss a tool out and buy a new one.
